Garden Logo
Posted on Jul 01, 2009
25cc trimmer gas ratio mixture
Whats the proper mixture ratio for a 25 cc homelite trimmer
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jul 01, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
806
Points
10
The correct ratio is 50-1 mix
What is fuel mixture on 25 cc craftsman weedwacker
This small engine needs a 40:1 ratio. Use only 2 cycle oil, not motor oil. If you are mixing one gallon of fuel use 3.2 ounces of the 2 cycle oil. This should give correct mixture so you do not get lots of smoke when you start. Take the time to measure. Note: there should be a marking somewhere on the engine about the mixture.
What is gas m ratio fr 25cc weer
Hello there
Download here friend.
http://manuals.homelite.com/system/files/4262/original/UT40502_UT40903_041_eng.pdf?2011
Page 8 of the Homelite user Manual gives you the EXACT ratio.
FUEL MIXTURE
'This product is powered by a 2-cycle engine and requires
pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded
gasoline and 2-cycle engine lubricant in a clean 1 gallon
container approved for gasoline.
Recommended fuel:
This engine is certified to operate on
unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mixlubricant with gasolineaccording to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US)'
Need oil mix ratio for 25cc homelite gas trimmer
Hi anon the mix ratio is 50:1. That's five litres of unleaded and 100 ml of 2 stroke oil
Correct fuel mixture for homelite zip start weedeater.25cc,ut20785..
50:1 five liters unleaded petrol and 100ml 2 stroke oil
2answers
How do i mix the gas/oil on a 25 cc 2 cycle craftsman weed eater
The specs say 40:1 so 3 - 3 1/2 OZ of 2 cycle oil in a gallon of gas.
1helpful
Fuel mix for 25cc trimmer
For two stroke engines of this capacity the ratio of fuel to two stroke oil is (25:1) 25 fuel to 1 (two stroke) oil. Eg 200 ml of two stroke oil to 5 litres of fuel.
1helpful
Homelite 25cc 2cycle trimmer.built in March of 1999. what is the proper oil to gas ratio?
If you use a synthetic 2-stroke oil, you can easily get by running a 40:1 ratio mix...that is 3.2oz oil/gallon of gas. A richer oil mix won't hurt either (say 20:1 (2X the oil of 40:1). I recommend synthetic always be used alongwith Stabil fuel treatment because after about 30 days, gas loses its volatility and begins to breakdown without it...causing fuel problems.
10helpful
4answers
Homelite zip start 2cycle trimmer.
I had this same problem, would run a couple of seconds, stop, and you couldn't start it again.
Had good gas/oil mix 50:1 and 25cc Homelite. Had replaced the fuel filter, gas, spark plug, and took carb apart and cleaned with carb cleaner and primer bulb worked fine. None of that fixed it. What did? Take the muffler off and see if it will start and run with the muffler off. If it does, chances are the muffler is clogged. Also check the exhaust ports and clean them out if plugged with black oil carbon residue.
My muffler was clogged up, took it off, cleaned out the exhaust ports, there was some oil that was in the muffler(oil that didn't burn during combustion). It now starts and runs like a champ on first or second pull.
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
