Take one co-axial cable, and connect the "input" port to your cable-company's wall-port.
Look at the connectors on the back of your TV. You could have:
* coaxial input (lowest video-quality)
* S-Video input (better video-quality)
* component input - three cables for video, two cables for audio (better video-quality)
* HDMI input (highest video-quality)
Look at the connectors on the "output" side of the PVR. You could have:
* coaxial output (lowest video-quality)
* S-Video output (better video-quality)
* component output - three cables for video, two cables for audio (better video-quality)
* HDMI output (highest video-quality)
Connect the "outputs" to the "inputs", using appropriate cables.
Turn the PVR on. Turn the TV on.
Use the "source" button on the TV's remote-control to select from the various inputs
(Coax, S-Video, Component, HDMI1, HDMI2).
If your TV has 'PIP' ("Picture-In-Picture") capability, connect more than one output to a second input, so that both tuners inside your TV will receive a signal.
Hi cathie
If you have sound it means that the tv is in aux/video mode.
Now make sure that the video output of the vcr is connected to the same aux/video input that has the sound connected to. i.e input 1 or 2 .
Also you want to try and switch with another cable to make sure that the cable you are using now is o.k.
Another way to try the tv input would be to connect something else in that input(cable box ,dvd ,video game etc,)
Try it and let me know.
This receiver has only one HDMI output, but 4 HDMI inputs. If some inputs don't work, try connecting the equipment (DVD for example) to HDMI input which works with other equipment.... For the RCA (composite) video input - it won't work, because this receiver don't have any video processing circuit. So HDMI input video goes to HDMI outout connector. Composite (RCA) video input goes to Composite outout and no other video output. S-video input goes only to s-video output.
audio input is sound like a microphone, mp3 player, cd player. Video input is dvd ,movie or other video input- Input is incomming to the computer. Like a hardware connection for physical download.
How do I connect direct tv to denon and then get sound If the RCA TV has HDMI input connect as follows: 1.Connect an HDMI cable from the Directv box to an HDMI input on the Denon. 2.Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV 3.Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV. 4.On front of denon press the input mode button to select auto If the RCA TV has Component input (Green,Red,Blue) connect as follows: 5.Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR). 6.Connect a Component Video cable from the Denon to the RCA TV Component Video input. 7.Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8.On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows: 9.Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR). 10.Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11.Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV. On front of denon press the input mode button to select auto
