Battery cover locking lug broken. cover needs replacement
SOURCE: I need to Repair my Fujifilm Digital Camera
I had the same problem with my S3100. Last year I sent it back to Fuji and the power board had to be replaced. It cost around $80.00 to get fixed. I got the camera back last Xmas and I am having problems again. You can call 1-800-800-3854 and talk to their repair dept. I am going to replace mine, it is ridiculous that you spend all this money on a digital camera and then have continuous problems. I have always had Fuji cameras and liked them, but I think I am going to try another brand.
SOURCE: Replace Battery Cover
Okay,
Separating the front and rear covers of the camera is not that difficult. You'll need a good small cross point screwdriver. I do not have a 2600 in front of me, but the 2650 is similar. Remove all the screws around the sides of the camera. The top sections are snapped together. work along the back edge to undo the snap tabs. I do not remember if there is a ribbon cable attached so go easy when you remove the back half.
My chat is not working yet, so if you want to go this far, let me know
SOURCE: battery cover
I've taken out the screws and the front and back still don't come apart. It appears as though there are screws under the cover of the hot shoe, but they appear to be screwed in from the bottom of the flash shoe. any suggestions
SOURCE: Fujifilm Finepix a825 Digital Camera Battery Life issue
2 long shots as I don't know anything about the a825
Some cameras have a setting in their menu that allows you to choose between alkaline or NiMh (rechargable). If the setting is wrongly set to alkaline when using rechargable it is unlikely to recognise that the batteries are charged and would report low battery. Check your manual to see if their is a select battery setting and check whether it is set correctly.
Occasionally errors on digital cameras can be corrected by removing the memory card and batteries, leaving for 2-3 days and then putting back in the batteries, turning on, turning off, putting the memory card back in and turning back on.
