My mcs-150 speakers are over 14 years old. I recently got a new computer with a gaming specific motherboard and when I plug in the mcs-150s the sound is low. I even placed all volumes on the pc on high but sound is still low coming from the speakers. I have updated all drivers and still sound is low from speakers. Is this maybe because the old speakers do not have enough wattage or something to work well with a new cutting-edge gaming motherboard (gigabyte GA-Z97-HD3) ?
SOURCE: speakers
SOURCE: labtec speakers want play
check whether the output plug is connected properly or not.... if it is then check out whether the adapter is giving the power output.... if it is then the speakers are spoilt otherwise u can just replace the adapter...
SOURCE: installing Labtec LCS 800 speakers
1 wire goes between the 2 speakers
1 wire goes from the speaker with 2 jacks in it to the computer, the back of the computer should have a green port to plug in the cable to
1 wire is the power
this is a guess without seeing your setup
SOURCE: wiring internal board of labtec computer speakers
The shielded wires are for ground, so they get connected together. Plug the wire into the PC and run some music. Then touch each wire to the others. You only have a couple of combinations to try...red-to-green and white-to-yellow, or red-to-yellow and white-to-green, . You can do this while the PC is one and music playing until you get sound thru the speakers. There virtually no current running thru the wires and you can't hurt the PC by doing this.
If the speakers use an external power supply, have it plugged in and working when trying these connection options.
Testimonial: "Totally what I needed. Thank you very much for your help! It's my first day on a website like this and I'm a believer already.. "
SOURCE: Labtec LCS-2424 speakers: left speaker stopped working
I have the same problem sir, only the speaker with volume
control works. Earlier I used to twist the volume control this
way and that way to get the sound from the other speaker also.
Now the same technique doesn't work anymore.
