2002 Oldsmobile Intrigue Logo
A
Anonymous Posted on Aug 17, 2014
How do you adjust rear end toe
Daughter backed into a stump bending all three "links" lateral, forward and "toe adjuster arm" it is parallel with and behind lateral link. I replaced all but the toe adjust arm
Bill Boyd
Level 3:
Top Expert:
  • Oldsmobile Master 53,816 Answers
  • Posted on Dec 27, 2016
Bill Boyd
Oldsmobile Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11946364
Points
172802
Replace anything that was bent and then have the rear end alignment done at a wheel alignment specialist shop
any specialist shop when doing a front alignment should always check the rear first as it controls the accuracy of the front job
4 Related Answers
Anonymous
  • 89 Answers
  • Posted on Aug 31, 2008
SOURCE: How to change tension adjust arm for Serpentine Belt
reomve belt then the tensior arm is bolted to block i think its just two bolts if i remember right then bolt new on and replace belt hope this helps
Anonymous
  • 149 Answers
  • Posted on Mar 23, 2009
SOURCE: How do you adjust brakes on 1989 olds cutlass with
There is an easier way. You can either get a brake spoon from a parts store or use flat screwdriver, jack up the wheel where it will turn,
look at the bottom of the backing plate there is a small oblong plug, remove the plug use a flashlight you should be able to see a wheel with cogs on it take the screwdriver and adjust either up or down and turn the wheel, you want it just tight enough to drag a little. Good luck dont forget to rate.
searcher1974
Bobby Blevins
  • 229 Answers
  • Posted on Sep 26, 2012
SOURCE: Self-Leveling Unit Sensor, the adjustable link is broke. Where can I buy a new one?
Ebay.
Thomas Beaver
  • 2119 Answers
  • Posted on Aug 17, 2014
SOURCE: How do I align the toe on the rear wheel?
Without proper equipment it's not likely that you can get it right. I suggest that you take it in for an akighment.
What is the "right way" to adjust rear toe/alignment
take it to a shop that does alignments and get it inspected, sometimes an experanced eye will see something you might not. then have a 4 wheel alignment done. this is the only right way to do this.
2answers
Wheel alignment specs
This is just a free chat room
We have no info like that
We are at home & use the site-- the same as you do
2answers
Can i adjust bent or toed out front wheel on 82 bronco?
The toe is adjusted by the tie rod ends connected to the gear box.
Some adjustment is possible where the tie rod ends connect.
5helpful
2answers
I want to know how to fix the alignment on my 1995 honda accord ex.
Before making wheel alignment adjustment, perform the following checks:
  1. Tires should be equal in size and runout must not be excessive. Tires and wheels should be in balance, and inflated to manufacturer's specifications.
  2. Wheel bearings must be properly adjusted. Steering linkage and suspension must not have excessive looseness. Check for wear in tie rod ends and ball joints.
  3. Steering gear box must not have excessive play. Check and adjust to manufacturer's specifications.
  4. Vehicle must be at curb height with full fuel load and spare tire in vehicle. No extra load should be on vehicle.
  5. Vehicle must be level with floor and with suspension settled. Jounce front and rear of vehicle several times and allow it to settle to normal curb height.
  6. If steering wheel is not centered with front wheels in straight-ahead position, correct by shortening one tie rod adjusting sleeve and lengthening opposite sleeve equal amounts.
  7. Ensure wheel lug nuts are tightened to torque specifications
Ride Height Adjustment
Before adjusting alignment, check riding height. Riding height must be checked with vehicle on level floor and tires properly inflated. Passenger and luggage compartments must be unloaded. Bounce vehicle several times, and allow suspension to settle. Visually inspect vehicle from front to rear and from side to side for signs of abnormal height.
Measure riding height. See figure. Riding height between left and right sides of vehicle should vary less than 1′ (25.4 mm). If riding height is not within specification, check suspension components and repair or replace them as necessary.
Wheel Alignment Procedures
Honda recommends using commercially available computerized 4-wheel alignment equipment. Follow equipment manufacturer instructions to obtain vehicle alignment settings. Use following procedures for necessary adjustments.
Civic Camber Adjustment
Compare camber settings with vehicle manufacturer recommendations. If camber is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck camber.
Civic Caster Adjustment
DO NOT use more than 2 shims. If more than 2 shims are required to adjust caster angle, check for bent or damaged suspension components.
Compare caster settings with vehicle manufacturer recommendations. If caster is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck caster.
Civic Toe-In Adjustment
  1. Secure steering wheel in straight-ahead position. Measure front wheel toe-in. If adjustment is needed, loosen tie rod lock nuts. Turn both tie rods equally in the same direction until front wheels are in straight-ahead position and toe-in reading is correct. Tighten tie rod lock nuts. Reposition tie rod boots if twisted.
  2. Ensure parking brake is released. Check rear wheel toe-in. If adjustment is needed, hold adjusting bolt on rear compensator arm and loosen lock nut. See figure. Adjust rear toe-in by sliding rear control arm until rear toe-in is correct. Install NEW lock nut, and tighten it while holding adjusting bolt.
Wheel Alignment Specifications
  • Camber - Measurement in degrees.
    • Front: 0 (range -1 to 1)
    • Rear: 0.33 (range -1.33 to 0.67)
  • Caster - Measurement in degrees.
    • 1.17 (range 0.17 to 2.17)
  • Toe-In - Measurement in inches (mm).
    • Front: -0 (0)
    • Rear: 0.08 (2.0)
  • Toe-In - Measurement in degrees.
    • Front: 0.00 (range - 0.16 to 0.16)
  • Toe-Out On Turns - Measurement in degrees.
    • Inner: 41.00
    • Outer: 33.50
Torque Specifications Ft. Lbs (N.m)
  • Rear Control Arm Adjusting Bolt: 48 (65)
  • Spindle Nut: 136 (185)
  • Tie Rod Lock Nut: 41 (55)
  • Wheel Lug Nuts: 80 (108)
hope this helps you out.
2answers
My daughter ran her 98 Civic EX into a ditch flattening the front tire on the right front and bending the entire rear left wheel inward. I replaced to lower control arm in the rear, but now the car has...
not a lower control arm problem
the wheel alignment guy is not lying
the front wheel drive only has tow in toe out adjustments
no camber adjustments
the frame is pre stressed at manufacture set at zero
if the shock tower frame on any front wheel drive gets bent up.... even a little bit
the camber will be way out
even front ride height may be way out on each front side
too dangerous to drive
the car is a write off
only good to sell for parts or buy the same model and swap over its good bits
if you like the car a lot
to correct the damage needs the front chassis stripped back to frame and put on a frame straightenerd47f961b-7315-43ab-a146-e3069f36ad5f.jpg
1helpful
Caster adjustment for 1990 jeep yj wrangler
caster is adjusted at the rear of the lower control arms. Camber is fixed and cannot be adjusted by normal means (though special off-set ball joints are available to do that) Toe in is adjusted by turning the sleeves in or out on the tie rod ends. None of this should be done at home though crude adjustments can be made in order to get the front end reasonably straight. Adjustments are made on an alignment machine that allows precise adjustments to all you mentioned as well as front/rear tracking.
2helpful
4answers
I keep having to replace wheels on my car.... the wheels are wearing unevenly i took it to a guy and he says the that there is a bar under there that keeps the wheels strait up and that bar is bent so my...
was your car in a wreck since you have own it?
that would be the only way anyone could bend steering or suspension parts.if your tires are leaning out on top,
it would be a part called"lower control arm assembly",
if you stand in front of your car with the steering wheel straight,and your tires are pointing in on each side,or pointed out instead of straight,that would be a "tie rod "
there is an inner tie rod and an outer tie rod end.
you need to take your car to a shop that does alignments,and have them tell you exactly what is wrong,you can even get lower control arm assemblies
from a salvage yard.but do yourself a favor and don't take your car to a MONROE or MIDAS type shop,they are only there to sell and make commissions! Find a normal shop that the owner is the mechanic.
3answers
Both rear tires are wearing on the inside.
you need an alignment. Its a toe-in, your tie rods need to adjusted. Check your tire pressure too.
1helpful
3answers
Wheel alignment
The main cause of steering wheel off-center is toe misalignment or rear axle misalignment. Toe can fall out of adjustment fairly easily as a result of daily driving, so you can imagine the effects of pounding it through 4WD trails on a regular basis.
Toe is designed to preload the steering linkage to remove play in the system. You can visualize toe angle from above; toe-in, or positive toe, is displayed when the leading edges of the tires are closer together than in the rear. Toe-out, or negative toe, is when the leading edges are farther apart. Zero toe is when wheels are pointed straight ahead and are parallel to each other. A slight amount of positive toe is preferred for most vehicles.
Improper toe angle isn't the only reason a steering wheel won't center. This phenomenon can also be caused by the steering linkage not being centered when toe was adjusted in the first place. This can be corrected by recentering the steering wheel and readjusting toe to proper specs. A bent steering arm or linkage component can also cause the steering wheel to be off-center. I've also seen this occur due to loose steering arm bolts. An off-center steering wheel contributes to tire wear because as the wheels are turned off dead center they turn toe out and increase tire scrubbing.
Sometimes an off-center steering wheel is accompanied by a wheel pull to one direction or the other and could be the result of a damaged component somewhere in the vehicle - a bent axlehousing could be throwing off the rear toe setting (rear toe setting is often overlooked). A bent frame or overly worn suspension bushings can also be the cause. If your wheel is off-center and also pulling, it can be as simple as incorrect tire pressure from side to side. Memory steer is another effect that is usually associated with an off-center steering wheel. This is when the steering wheel returns to an off-center position and can result in steering pull or drift after completing a turn. This can be caused by binding in the steering linkage as well as power steering system issues such as leaks or improper hydraulic pressure. Steering linkage bind occurs when proper geometry is not maintained in lifted vehicles.
Many 4x4s don't have factory provisions for adjusting caster and camber and rear toe and camber, but the front toe setting is easily adjusted. Toe is controlled by the steering linkage. By loosening the adjusters on the tie rod and shortening or lengthening the tie rod by turning the ends, toe angle can be adjusted. This should not be a substitute for regular professional wheel alignment jobs and is simply a tip that can be used to put off frequent trips to the alignment shop due to regular trips to the trail.
Before determining toe angle and/or performing adjustments, it's a good idea to start the engine and turn the steering wheel side to side to relieve pressure in the system. Then, turn the wheels straight and shut off the engine. You should also roll the vehicle back and forth a few times between measurements.
Get someone to hold the other end of the measuring tape and measure the leading toe distance. This is the distance between the leading edges of the front tires. You'll compare the results to the distance between the trailing edges of the tires directly opposite from where you took the first measurement.
The higher number will indicate toe direction: higher number in leading edge indicates toe out; higher number at trailing edge displays toe in. Larger-than-stock tires require more positive toe for best results.
Once the necessary measurements are performed to determine what the current toe setting is, you can loosen the bolts on the tie-rod adjuster sleeve so that the tie-rod ends can be rotated. Don't forgot to tighten the adjusters when you're done as damage or injury could result.
The tie-rod ends thread into the tie rod. The ends can be threaded in or out of the tie rod to make the assembly longer or shorter. Longer creates more toe out; shorter toe in. Don't make huge adjustments all at once. It's best to adjust and measure a few times to achieve appropriate setting.
I hope this helps you if you were looking to do a toe alignment yourself if you have decent knowledge of component location on a jeep.
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you an Oldsmobile Expert? Answer questions, earn points and help others
