I can access the service menu however when i get to systems on the list the menu goes off and wont let me get past it..i have already enabled the usb port to play music and pics by changing the model from the service menu
SOURCE: usb problem lg pq2000
pq2000 does not have a movies option for USA, the pq3000 does. I also have the 2000..
SOURCE: I have LG LF20 32
Even I am facing the same issue. Not able to enter into the service mode of 32LF20. Followed the steps from site http://www.answerspice.com/c134/425606/how-do-i-use-the-usb-on-my-lg-lf20-tv.
SOURCE: My lg lcd tv has a usb port but only recognises
You need to activate it first, here are the steps:
1. Press the enter(OK) both on the remote and the TV at the same time...hold for about 5 seconds
2. Password - 0000
3. Go to tool option 3
4. Change Jpeg to 1
5. Change Divx to SD or HD
6. Exit and try it out.
You will notice that now there are 8 inputs in the option list instead of 6 - Including a USB input.
Hope this helps
SOURCE: I have a LG 42LD450, I read and saw videos online
I used a Magnavox MG500S, some simply use a Comcast Cable remote, some just use a universal from radio shack......all in all....once you get the remote programmed to the TV you have to find its "Magic Button" to open the password screen........then enter code.(0413) for the remote I used. Some were using code 0000. All in all I guess it depends on the remote used.......sorry I cant help anymore than that.........then I can if you find the same remote I used!!!
SOURCE: I have the lg 42ld450
Hi my nameis Mike Houston of DISH Network and I see you are trying to play movies throughyour LG TV. I will send a link to help program the remote to the LG TV, http://www.dishnetwork.com/SupportSection/power-scan-instructions.If the DISH remote is programmed to the TV and you still can not get into theService Menu you will need to refer to the TV manufacture, I will send the linkto help with that, http://www.lg.com/us/support/index.jsp.
[1] Connect the USB device to the USB IN jack on the side
of TV.
After connecting the USB IN jack, you use the USB
function.
When you connect a USB device, this pop up menu is displayed automatically.
When the Pop Up menu does not appear, you can select Photo List or Music List in the USB menu.
In USB device, you can not add a new folder or delete the existing folder
[2] Select PHOTO LIST or MUSIC LIST.
[3] Press enter.
