I don't know how to program my at&t uverse remote to my program tv.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
SOURCE: Proscan TV Manual
I have a Proscan model # PS36800HRJX1 and having a hard time putting it on DVD mode to be able to play a movie. I just bought a remote for it and can't figure out what's the problem. How do I go about it?
SOURCE: proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
SOURCE: Programing Remote
1343 or 1005 are the codes - press the TV mode button and the OK button together - the release at the same time - the top row of mode buttons needs to blink twice - then enter the code - the TV button should blink 2 times - try the power and volume buttons - if it worked then be sure to press the ATT mode button again after so you can change the channels
SOURCE: I need the remote control code for Proscan tv with dvd player
Don't know if the 26" is the same as the 32, but 10019 works for the 32".
