Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston data traveler shows as skymedi drive
I can not format the drive form disk manager or with any software like partation magic etc. i shall be very thakful to you.
regards
rizee
    Sniper:
  • 68 Answers
You can follow the below commands
got to run
type cmd and press enter
then formatdrive name: and press enter
then it will ask for yes or no
press y
again do the above step once again your drive will be format
Posted on Jul 01, 2009
SOURCE:
I have Kingston Data Traveler size 4 GB, Now it become write protected and never allow to format. Further, it shows skymedi instead of Kingston. Please help me.
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7 this will also apply to usb drives
right click on your usb drive select properties select sharing then select advanced sharing make sure there is a tick in the share this folder box
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F: D: or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
click start click on my computer to open you should see your drive
another way:
click start all programs accessories open windows explorer click on my computer you should see your drive click to open it also right click select send to desktop to make shortcut
click start click on my computer you should see your 4 GB data it might be listed as a mass storage device
right click then select format
another way is to control panel administrive tools computer management disk management right click on your -GB data traveller select format
if you need more help with this post a reply
hope this helps you
Sep 14, 2011 | Kingston Technologies 512MB DataTraveler I...
Sudenly kingstone usb changed to skymedi and doesnt formated
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved.
How to save data
To save data, use software full version, for example, you can use EASEUS Data Recovery. After the data is saved, do the repair flash drive.
Repair flash drive Kingston
1. Right-click the flash drive, select Format - select quick format. If this does not work, don't repeat, do the second.
2. Format from Administrative Tools.
Win XP: click START - Control Panel - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - select quick format
Win Vista & 7: click START - Control Panel - select View by: Large Icons - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - Perform a quick format - OK. If this does not work, don't repeat, do the third process.
3. Format using the software, the HP USB Disk Storage Format Tool. Make the process quick format. If this does not work, don't repeat, do the fourth.
4. Repair the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extract
How to use the software HP Drive Key Boot Utility
For Win XP, first way
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win XP, second way
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7, first way
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way
Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps.
Sep 04, 2011 | Kingston Technologies 512MB DataTraveler I...
How to format Kingston 64GB Data Traveler 101
insert your kingston 64GB drive
click start right click on my computer select open you should see your pen drive
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
Jan 30, 2011 | Computers & Internet
I have lock my Kingston from imation lock.
you can try formatting it from the disk manager.
plug in the flash drive and remember what drive letter it gets assigned. right-click 'my computer' and choose manage from the drop-down menu. in the following window, click on disk management (under storage) on the left, then right-click on the flash drive and choose format...
Jun 22, 2009 | Kingston Technologies 512MB DataTraveler I...
Skymedi USB drive is not recognised on my computer
i have usb kingston 4 GB data mini traveler, and my problem usb detect skymidi usb drive i dont know skymedi. i don't want if have format,because there are many data which is of important.
how is it's solution.
thanks 4 all
by blurz
Feb 20, 2009 | Kingston Technologies 512MB DataTraveler I...
8GB Kingston Data Traveller only has 101mb available!
Hi Cristina,
This is Azeem Inam. your data traveller does not accept data over 101MBs. There can be two reasons for this problem. 1. there may be a virus that has provided a limitation on the copying facility. 2. This can be a partition problem. All you need to do is to use the software called DM (Disk manager). This is a DOS versioned software. Go into its advance installation option and then accept the hard disk kingston data traveller. It will take you to another menu showing the partition styles you may choose. you'll have to choose FAT32 type. then in the next menu you'll have to choose partition size by pressing enter button. and then accepting format you are done. it will start working as new again. Thanks for consulting your problem.
Feb 13, 2009 | Kingston Technologies 512MB DataTraveler I...
How to format a pen drive?
Try HP formatting tool with administrator previliages in vista
Nov 29, 2008 | Kingston Technologies 512MB DataTraveler I...
512MB KINGSTON DATA TRAVELER BECOMES SKYMEDI USB DRIVE USB DEVICE..PLS HELP
I think that I have a similar problem (and a potential solution)
1. My thumb drive is 4GB "super talent", and I have used it for about 2years
2. Suddenly, it show up as "REMOVABLE" SKYMEDI USB DEVICE (!)
3. I tried "google" for answer... and did not get further
4. Finally, I righ click on "my computer" -> select "manage" the "computer management" MMC windows open
4.1 I tried the "Disk Management" and it still can not connect to it
4.2 I clicked on "Removable Storage" ... and then I "SKYMEDI..."
4.3. I righ click on the device and select "Task" -> "Free" (thinking ... what can be worst!)
4.4 ... sunddenly ... I see my drive back ... with everything on it....
I hope that this help (... I am guessing that the "removable storage" manager locked this device somehow)
Regards
Jul 07, 2008 | Kingston Technologies 512MB DataTraveler I...
I can't format my 512MB kingston data traveler
Dude I just fixed mine running the SKYMEDI tool version SK6211BA_20080917 on my 8GB kingston datatraveler 100 is hard to get it but you will find it, you need to determine what version of the sw applies to your flash drive, check the SKYMEDI website www.skymedi.com.tw
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
1,815 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
