Canon PIXMA  MP160 All-In-One InkJet Printer Logo
Posted on Jul 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Help me evnethough the cartridge full of ink but whenever i print the empty paper coming out i do no y ?
Anonymous
Level 1:
Problem Solver:
  • Contributor 24 Answers
  • Posted on Sep 05, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
24
Questions
0
Helped
8703
Points
24
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ptttq9
Anonymous
Level 2:
  • Expert 34 Answers
  • Posted on Jul 01, 2009
Anonymous
Expert
Level 2:
Answers
34
Questions
0
Helped
15025
Points
114
Did you remove the tape from the print cartridges before installing them in your printer?
2helpful
Printer ink cartridges full but nothing comes on the paper
Try those solution:
- Clean the head within the printer maintenance mode.
- If you filled the cartridges by yourself, make sure that you empty the cartridges of air after filling it with ink!
Error E and 5
Number following "E"
Cause
How to correct
No paper. /
Paper does not feed.
If paper is not installed, load it and then press the <Black> or <Color> button. When paper is installed, check each of the following items and try printing again.
1. Confirm only recommended paper is installed.
2. Confirm paper is installed properly.
3. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
4. Clean the paper feed roller to resolve the error.
Paper jam
Remove the jammed paper.
If paper jams frequently occur, check the following:
1. Confirm there is no foreign material inside the machine.
2. Confirm only recommended paper is installed.
3. Confirm paper is installed properly.
4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
Empty ink tank
An ink cartridge is empty.
To cancel printing, press the <Stop/Reset> button.
To continue printing, press <Black> or <Color> button.
After printing completes, replace the empty ink cartridge.
Printing with an empty ink cartridge may cause the machine to malfunction.
5
The ink cartridge(s) is not installed. / The ink cartridge(s) cannot be recognized.
The ink cartridge may not be installed properly, or an unsupported ink cartridge may be installed.
Install a recommended ink cartridge.
Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing.
If one of the ink cartridges is missing, this error can occur.
7
The ink cartridge is not installed in the appropriate position.
The ink cartridge is not installed in the proper position.
Install each ink cartridge in the proper position.
8
The waste ink absorber is almost full.
The waste ink absorber is getting full.
Press the <Black> or <Color> button to clear the error and continue printing.
Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
9
A specified period of time has elapsed without receiving a response from the digital camera. / A print mode compliant with PictBridge is not selected. / A specified period of time has elapsed without receiving a response from the digital camera.
The machine cannot communicate with the connected camera.
Disconnect the cable between the machine and the camera to clear the error.
Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the machine.
1 , 4
1 , 5
The ink cartridge cannot be recognized.
An unsupported ink cartridge may be installed.
Install only recommended ink cartridges.
1, 6
The ink level cannot be correctly detected.
A used ink cartridge may be installed, or the ink cartridge is empty.
Replace the ink cartridge.
Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
1 , 9
Scanning failed.
Scanning a document failed.
Check if the document is placed in the correct orientation / position and try the operation again.
2 , x
3 , x
4 , x
(Where x represents a number)
Turn the machine off, and remove the power cord from the electrical outlet.
Wait approximately ten minutes then plug in the power cord and turn the machine on.
If the problem is not resolved, the machine may require service.
2answers
Printer won't print B&W even though black cartridge is full but 2 colours are empty.
Although you are only trying to print a B & W picture, the color print cartridge/cartridges must also contain ink in order for the printer to work. All print cartridges must contain ink for printing of any type to take place.
Load the color print cartridges and the B & W picture will print.
If you were trying to print a color picture and the B & W cartridge was empty, the printer also, would not print.
I hope this helps you out.
Good Luck
1helpful
U053 error code,tried removing and replacing cartridges, but code still present,cartridges are compatible as come with printer.
Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
Make sure to install both the ink cartridges even when you set the printer to use only one ink cartridge (Color or Photo) in printing.
If one of the ink cartridges is missing, this error will occur. U075 / U076 The ink cartridges are not installed in the proper position.
Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
By pressing the OK button, printing can be done without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate. READ/WRITE MODE Since the memory card is currently write-enabled, printing is not possible.
Set READ-ONLY MODE ON. NO PHOTOS ON CARD Some images in the memory card may not be in a supported format. images listed below cannot be printed directly from a memory card. Print them from a computer.
- images edited on the computer
- images in a format other than JPEG or TIFF
- images with double-byte characters used in the file name
- images saved in a folder nested 4 or more layers deep INCOMPATIBLE CAMERA The printer cannot communicate with the connected camera.
Disconnect the cable between the printer and the camera to clear the error.
Confirm the following items and print again.
If the camera does not support either one, the printer cannot print directly from the camera.
Please refer to the camera instructions for more information about procedures required before and after connection to the printer.
Re-connect the cable between the camera and the printer. WASTE INK NEAR FULL The waste ink absorber is getting full.
Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and printer maintenance.
The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc. CHECK PRINTER Turn the printer off, and remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If the problem is not resolved, the printer may require servicing. Please contact your local Service Center. HEAD ALIGNMENT ERROR Automatic print head alignment failed.
Press the OK button to release the error.
Check the followings and do automatic print head alignment again.
- Check if A4/Letter-sized paper is loaded in the auto sheet feeder.
- Check if the paper output slot is not exposed to a strong light source
- Print the nozzle check pattern to check the status of the print head.
If the problem continues, do manual print head alignment. LOAD PAPER If paper is not set, set paper and press the OK button. When paper is set, check each item and do printing again.
1. Confirm that unusable paper is not set.
2. Confirm that paper is set properly.
3. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
4. Cleaning the paper feed roller may resolve the error.
If the problem persists, the printer may require servicing. Please contact your local Service Center. PAPER JAMMED Remove the jammed paper.
If paper jam frequently occurs, check the following:
1. Confirm that no foreign material is inside the printer.
2. Confirm that unusable paper is not set.
3. Confirm that paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
2answers
My printer is printing in pink color how can i change it to black
Sounds like your black cartridge is either empty or clogged. Take out the black cartridge and press the print head against a moist paper towel. You should see a nice black rectangle, if you don't you could try placing the print head on a wet paper towel for a few minutes to wick out the ink (ink may seep through the paper towel so beware what surface you do this on). If after this there is still no ink flowing, buy a new cartridge.
Error Message U053
Error messages displayed on the LCD and how to handle them
When an error has occurred in the printer, the error / check message is displayed on the LCD.
Take the appropriate action to return to the normal condition.
Error / Check message How to correct CHECK INK
U041 An ink cartridge is empty.
To cancel printing, press the Stop/Reset button.
To continue printing, press the OK button.
After the printing finishes, replace the empty ink cartridge.
4helpful
Cyan ink was full - now it's empty a day later?
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
1helpful
Mp140 e2
E3 – Paper jam error.
How to correct, fix: Remove the jammed paper. If paper jams frequently occur, check the following:
E4 – Empty ink tank.
How to correct, fix: An ink cartridge is empty. To cancel printing, press the <Stop/Reset> button. To continue printing, press <Black> or <Color> button. After printing completes, replace the empty ink cartridge. Printing with an empty ink cartridge may cause the machine to malfunction.
E5 – The ink cartridge(s) is not installed. The ink cartridge(s) cannot be recognized.
How to correct, fix: Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing. If one of the ink cartridges is missing, this error can occur.
E7 – The ink cartridge is not installed in the appropriate position.
How to correct, fix: The ink cartridge is not installed in the proper position. Install each ink cartridge in the proper position.
E8 – The ink wasteabsorber is almost full.
How to correct, fix: The waste ink absorber is getting full. Press the <Black> or <Color> button to clear the error and continue printing. Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service. The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
E9 – A specified period of time has elapsed without receiving a response from the digital camera. A print mode compliant with PictBridge is not selected. A specified period of time has elapsed without receiving a response from the digital camera.
How to correct, fix: The machine cannot communicate with the connected camera. Disconnect the cable between the machine and the camera to clear the error. Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct. If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge. Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time. Re-connect the cable between the camera and the machine.
E14 – Ink cartridge cannot be recognized.
How to correct, fix: Unsupported ink cartridge may be installed.
E15 – Install only recommended ink cartridges.
How to correct, fix: Install only recommended ink cartridges.
E16 – The ink level cannot be correctly recognized or detected.
How to correct, fix: A used ink cartridge may be installed, or the ink cartridge is empty. Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
E19 – Scanning failed error.
How to correct, fix: Scanning a document failed. Check if the document is placed in the correct orientation position and try the operation again.
5helpful
5answers
Epson C66 won't print without color cartidges
epson printers won't really print if one cartridge is not detected or detected as empty. the only option that i can suggest to you is that, buy a continous ink kit at any ink refilling station in your place. i highly recommend that dont leave a cartridge empty with ink cause it might clog your printhead. using a continous ink system's cartridge is auto reset, whenever the printer says that the cartridge is empty, it will automatically resets itself. ink refill kit comes with 100+ml of ink per color i think. and it is much cheaper using original epson ink.
old marine
old marine
ZJ Limited
ZJ Limited
