Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
A
Anonymous Posted on Aug 16, 2014
Why won't my coffee maker start?
Clock works just won't start to grind and make coffee
5 Related Answers
Anonymous
  • 667 Answers
  • Posted on Jan 11, 2008
SOURCE: I forgot to place my coffee filter back in the coffee maker
Just an idea, but you could use a turkey baster to remove some of the water first. I doubt if you've harmed the coffee maker.
co7196
Ned C Cook
  • 3433 Answers
  • Posted on Sep 24, 2009
SOURCE: I have a cuisinart with brew and grind coffee
Stuck? how stuck can it be when it is supposed to be removable? Try turn ing it,
Anonymous
  • 9 Answers
  • Posted on Feb 08, 2010
SOURCE: Coffee maker won't start brewing process
brew light is off
Anonymous
  • Posted on Dec 10, 2010
SOURCE: cOFFEE MAKER LEAKS CLEAR WATER FROM THE BOTTOM EVERY TIME I USE T
Have the same issue, looking for my receipt for warranty. All of us having this problem can't be wrong and it must be defective
Anonymous
  • Posted on May 27, 2012
SOURCE: coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Having trouble programming my grind and brew coffee maker. Did not come on at specified time
Sometimes these machines get "confused" as it were. Try unplugging it from the mains, wait about an hour or two, plug it in again, reset the clock and the timer...
9helpful
Coffee not brewing after grinding
After grinding did you hear the brew group goes up and pump start? If you hear the pump start and stopped, itis blockage in the brewunit metal screen. Just needs cleaning.
If you don't hear the pump starting, the problem is with the faulty micro switch inside the gearbox , that is behind the plate of brewunit.(service center job)
7helpful
3answers
Grind Off light blinking
Mine was doing that for the past week. I think it was indicating there had been a power outage but that the clock had not reset to zeros. I changed the time a couple of minutes and it stopped.
I received a Cuisinart Grind and Brew 10 cup coffee maker. Can you tell me how to set the time on it?
Press and hold the HR button for a few seconds until clock time starts flashing, then press and release the HR button to change the hours
Do the same with the MIN button
Note: on this coffeemaker, the display will say "PM" if it is set for PM - otherwise it will be on AM
Cuisinart grind and brew beeps, but won't brew
we unplugged it for 10 minutes or so, plugged it in again, beeping stopped and it works again.
Keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Top Cuisinart Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
john h
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
