Question about General Electric WCVH6800J Front Load Washer
How do you fix wcvh6800 basket that is loose and needs to be rebalanced?
I got this ge wcvh6800j front loaded washing machine from a friend who was getting rid of it because the basket banged and would shake the whole machine violently. As I looked at it the basket is loose and it seems like it is just out of balance. The springs look okay. I don't have the manual and was trying to see how to take the outside off so I could see if I could rebalance. What suggestions or ideas do you have. Also how do you rebalance the basket?
6ya staff
SOURCE:
Anonymous
  • 373 Answers
SOURCE: WCVH6800J GE Front loader timer keeps resetting
The clock timer might be faulty.Need to Replace it.Since the machine is new, it must be under warranty and can be subjected to replacement.Problems with clock timers is common with any washer.Its better when detected early like in this case.Good luck.Please do post your comments.
Posted on Jan 16, 2009
Bill Erickson
  • 29 Answers
SOURCE: ge WCVH6800 front load washer.
Has this been solved? I have the same problem only I do not remember a power failure. But the other things are the same. <!-- from fixya rte -->
Posted on Aug 16, 2010
cricketworks
SOURCE: MAJOR leak in new JUST installed WCVH6800 front load washer
If you hear of a solution, let everyone know. Our machine did the same thing. From the research I have seen, GE makes **** machines and I will NEVER buy a GE product again.
Posted on Oct 25, 2010
Czerney Dort
  • 170 Answers
SOURCE: Heavy loads like rugs do
Check for any movement from corner to corner (across corner to corner) if there is any AT ALL adjust legs to take up the movement / no movment is more inportant then being level a lot of techs miss this... anymore questions or problems just ask .....good luck
Posted on Feb 01, 2011
Christopher Young
  • 44 Answers
SOURCE: A red padlock symbol
Here's what the Padlock represents:
Lock Function
You can lock the controls to prevent any selections from being made. Or you can lock the controls after you have started a cycle. children cannot accidentally start the washer by touching pads with this option selected.
To lock the washer, press and hold the DELAY START button for 3 seconds (on some models use SIGNAL button). To unlock the washer controls, press and hold the DELAY START button for 3 seconds. The control lock icon on the display will light up when it is on.
NOTE: The POWER button can still be used when the machine is locked.
Posted on Jul 28, 2011
My ge dryer basket is knocking
In a front load washer, this can be an indication of defective bearings.
Jun 21, 2014 | General Electric WCVH6800J Front Load...
Replace pump wcvh6800
Bought mine on amazon easy replacement
Dec 07, 2013 | General Electric WCVH6800J Front Load...
GE Model WCVH6800 keeps pausing mid-cycle. I understand how to run the diagnostic but can't seem to get it to work. I unplug for 30 seconds and hit signal, delay, signal, delay but upon hitting the...
It stumped me first time. You have to unplug it, plug it in, then press signal-delay-signal-delay with in 30 seconds. You don't push any othere buttons first. Then it will lock the door, spin the drum, and go into troubleshooting mode.
Sep 24, 2011 | General Electric WCVH6800J Front Load...
A red padlock symbol is showing on the panel of my WCVH6800 front load washer. I can't change any of the wash settings. How do I fix this?
Lock Function
Jun 28, 2011 | General Electric WCVH6800J Front Load...
Ge WCVH6800 front load washer. Power was interrupted during washing cycle. Machine counts down 3.6 minutes, then goes off. How do you correctly reset cpu or test system
Here how you "test" the system: http://www.fixya.com/support/t9576766-found_small_part While in test mode "t02", you can reset all the error codes by holding down Start until it displays E00. If you find errors in the t02 test, make sure you write them down before clearing.
Dec 11, 2010 | General Electric WCVH6800J Front Load...
Have a new ge WCVH6800 front load washer. Power was interrupted during washing cycle. Machine now stays in drain mode, stops after 3 minutes, door unlocks and start/ pause button flashes. How do you...
Hello there and welcome to fixya
You may want to try unplugging the machine for a minimum of 2 hours to let the internal cpu to reset itself then plug it back in then press the mode button then try to lock the door and it should be ok after that ok please inform me how this goes there is more we can do for this ok
Best regards Michael
Feb 28, 2010 | General Electric WCVH6800J Front Load...
Feb 07, 2010 | General Electric WCVH6800J Front Load...
Jan 16, 2009 | General Electric WCVH6800J Front Load...
General Electric WCVH6800J Front Load Washer Logo
63 people viewed this question
Top General Washing Machines Experts
Kevin
Kevin
geapptech
Dw Wooten
Dw Wooten
Are you a General Washing Machine Expert? Answer questions, earn points and help others
