SOURCE: F3 Error Message
It needs a new key pad it is shorted the ge website has a list of error codes f3 is the keypad
SOURCE: F3 Message and Beeping
On a GE/Hotpoint, F3 means you have a failed keypad.
If you or someone you know might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
It's at http://www.microwavedisplay.com/keypad_replacement.pdf
If you'd rather have us fix it for you, we do that for $39.95 plus parts and you can visit us via our link here on Fixya http://tinyurl.com/yzjozk
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
SOURCE: The oven doesn't work. Gives an F2/F3 error. This
f3 code temp sensor circuit bad ,f2 oven temp higher 500 degrees
SOURCE: F3 error GE Spacemaker XL 1800: Model JVM1851CD.
F3 on a GE / Hotpoint
microwave means you have a shorted membrane keypad (aka membrane switch).
If and when an oven is coming on or doing anything by
itself, this is very dangerous and can result in a fire.
So until it is repaired,
please leave it unplugged or leave the door
open when it's not in use, and of course one should never leave a microwave unattended while cooking.
If you (or someone you
know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically
involved.
You can find
helpful exploded view diagrams and order parts by entering your full
model number here.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.
If you would like to
have us
do this repair for you, we do that for $39.95 plus part costs nationwide.
Either way, we can let
you know what your options and costs would be and send you other
helpful info.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more
information & help.
We're
happy to help you with free advice and we'd appreciate your thoughtful
[email protected]
Microwave Oven Control Panel Repair Nationwide
SOURCE: ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
