Measure the length of both legs. Sometimes post # femur if not properly reduced in time, due to muscle spasms the leg is shorter.which means that you are walking tilted to your injured side. It may only be slight, but it does place a strain on the lower back region.
Put the control (on the driver door for your side view mirrors) onto the passenger mirror position put the car in reverse, mirror tilts down and shows you the curb! (this only works on some models like the 3.0 not sure of what year of 1.8t)
You more than likely knocked a connection loose in the circuit. Like some stated earlier this could simply be a busted wire or it could be a completely broken connector. Electric trimmers are a lot more likely to be damaged from jostling than gas trimmers.
Mirror Tilt in Reverse Controls
This feature is capable of tilting the passenger side power mirror when the transmission is placed in reverse to provide enhanced visibility during parking or backing maneuvers. This feature is turned OFF or ON through the DIC. The passenger mirror on domestic vehicles can not be changed from the factory setting, but on export vehicles, the passenger mirror position may by changed using the same procedure as the driver mirror. For further information, refer to Driver Personalization in Personalization.
Tilt Mirror In Reverse
Continue with the following steps in order to personalize the tilt mirror in reverse.
Press the Select button in order to enter the menu. The first choice seen is the current setting.
Press the Select button in order to scroll through the following options:
• CURB VIEW: OFF (Default)
• CURB VIEW: PASSENGER
Press the Personalization button in order to advance to the next option.
this might be what you're experiencing.......
Park Tilt Mirrors
If the vehicle has the memory
package, the outside mirrors
have a park tilt feature. This feature
automatically tilts the outside
mirrors to a preselected position
when the vehicle is in R (Reverse).
This allows the driver to view the
curb for parallel parking.
The passenger and driver mirrors
return to their original position
when the vehicle is shifted out of
R (Reverse), or the ignition is turned
off or to OFF/LOCK.
This feature can be turned on or
off through the Driver Information
Center (DIC)
The audio system controls are used
to access the personalization
menus for customizing vehicle
features. (DIC)
CONFIG (Configuration):
Press
to access the Configuration
Settings Menu.
MENU / SELECT Knob:
Press the
center of this knob to enter the
menus and select menu items.
Turn the knob to scroll through the
menus.
0
BACK:
Press to exit or move
backwards in a menu.
MY POWER SEATS WILL GO UP & DOWN AND WILL TILT FORWARD & BACKWARDS BUT WILL NOT GO FORWARD OR BACKWARDS. IT JUST MAKES A HUMMING SOUND WHEN TRYING TO GO FORWARD OR BACKWARD. IS THE POWER SEAT SYSTEM A GEAR SYSTEM, OR HYDRAULIC SYSTEM?
ya take it into www.buggypitstop.co.uk the are the only people inthe uk that repairs the handle everywhere else they will quote you around £200 pounds to replace the handle
