Sony Xperia miro ST23i Smartphone - Unlocked Black Pink Logo
A
Anonymous Posted on Aug 16, 2014
What will i do i forgot the security question for xperiast21i2 to unlock the pattern lock what would i do?
I bought new Samsung CE0700 . I set my screen pattern to lock and unlock. After 24 hours I forgot my screen pattern to unlock. Can you help me unlock my screen pattern please ?
  1. Navigate to Apps > Settings > Lock screen and security.
  2. Touch Screen lock type.
  3. Touch Pattern.
  4. Create a screen unlock pattern by connecting at least four dots in vertical, horizontal, or diagonal directions. ...
  5. Draw the pattern again. ...
  6. Enter a backup PIN. ...
  7. Enter the PIN again.
I can not unlock my screen and I'm not getting a Goggle prompt or a prompt "forgot pattern?" to respond to.
To unlock the device using a Googleâ„¢ security question
  1. After multiple failed attempts to unlock the device, tap Forgot pattern?.
  2. Tap Answer question.
  3. Type the answer, then tap Unlock.
  4. Tap Yes if you want to create a new unlock pattern, or tap No if you don't want to use a screen lock.
Dec 03, 2015 • Cell Phones
Forgot unlock pattern on my device, can you help unlock it/
from the internet.....The default password is 123456 try it and if you make it uninstal mccafe after that... or
https://www.mcafeemobilesecurity.com/forgot-password.aspx
or try this if its your lock pattern
https://www.youtube.com/watch?v=YreKlS68NMs
May 30, 2015 • Cell Phones
Forgot my pattern password on my budget mobile verizon phone
After pressing OK or waiting the 30 seconds, press navigation key to bring up screen again. I'm guessing you have a Motorola phone, but maybe not. You will get back to the security lock screen but there will be a button on bottom right that states Forgot pattern (or passcode). If you forgot your screen unlock pattern or passcode, tap Forgot pattern (or passcode). You will be prompted to sign in using the Google account you programmed into the handset during initial start up. If successful, you will move to next screen to create a new security lock. You can cancel out of that step and return to homescreen.
Feb 01, 2015 • Cell Phones
3helpful
I forgot my screen unlock pattern what i do?
Reset the screen unlock pattern
If the incorrect screen unlock pattern is entered five times in a row, the phone is locked.
Note: In order to reset the screen unlock pattern you need to have a registered Google account on your phone. If you don't have a registered Google account on your phone, you must repair the phone software before tapping Forgot pattern.
To reset the screen unlock pattern by answering a security question:
  1. If entering the incorrect screen unlock pattern five times, wait for 30 seconds and then tap Forgot pattern?.
  2. Tap Answer question > Next.
  3. Enter the answer for the security question.
  4. Tap Unlock.
To reset the screen unlock pattern by entering Google account details:
  1. Tap Enter Google accounts details > Next.
  2. Tap the Username field and enter the phone registered Google account username.
  3. Tap the Password field and enter the phone registered Google account password.
  4. Tap Unlock.
To repair the phone software:
  1. On the computer: Open PC Companion 2.0.
  2. In the Support Zone application, click Start > Repair and follow the instructions on the screen.
Note: The installed software on your phone will be replaced, and all personal data stored will be lost.
Tip: If it is not possible to repair the phone software, please contact your Sony Ericsson Customer support.
Forget the pattern lock
  1. On the unlock screen, attempt to enter your unlock pattern five times.
  2. When prompted to wait for 30 seconds, tap OK.
  3. If the display goes off, press the POWER button to turn the display back on and then press the bar on the lock screen and slide your finger down to unlock the screen.
  4. Tap the Forgot Pattern button in the lower right corner when it appears.
  5. Enter your Google Account name and password, and then tap Sign in.
You are then prompted to create a new screen unlock pattern. If you no longer want to use a screen unlock pattern to secure your phone, tap Cancel.
7helpful
My lava iris n320 mobile is locked by mistake how i unlock it
my mobile phone lava n320 has pattern lock i forgot my security.....how to unlockit
Dec 29, 2012 • Cell Phones
2answers
How do i unlock draw pattern on my samsung galaxy y
go to 'applications', then 'settings', then select 'location and security.' there should be an option that says something about a passcode, screen lock, or security. the pattern lock should be one of the options that comes up.
6helpful
4answers
My samsung gt 19000 is loked as my son put wrong pattern so please tell me how to open the lock
Unlocking Phone Don't worry there isSolution to Unlock the Mobile Phone from the Security Lock....Use the MasterReset Code and Unlock the Mobile....I unlocked my mobile Nokia 6600 using theMaster reset Code,I got the Master Reset Code here http://www.superunlockcodes.com/unlocking-services/rs12wp6/and Unlock it........You Check Master Reset Code for Your mobile in the List.
Top Sony Cell Phones Experts
Aron
ADMIN Eric
ADMIN Eric
NOEL
NOEL
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
