Hubby removed door panels checked motors they are good the cables are so tight will not move, the rear window on driver side quit working about a year ago, then the rear passenger stopped working about a month ago. Any help would be greatly appreciated
Would seem your into the inner doors & have a partial
grasp on things
Now you fix all door windows one shot
#1 Test all switches,ohm meter unplugged or volt meter with power
#2 Test all motors with battery voltage direct -- DC motor will run either direction-- can't hook up wrong
#3 Window Regulators -you know about them (Unless they are broken-you said they are tight)
#4 Do you have good ground side wiring & battery voltage at all
switches & motors
#5 Last resort--unhook the cables & work on freeing up the
glass & window guides etc then you will have found out if the
regulators are the issue
SOURCE: 2004 Jeep Grand Cherokee driver side power windows do not work
I had the same problem with now power to windows, mirrors and seat. The common soulution is the orange and or black wire in the boot have broken between the door and post.
SOURCE: Remove inside panel pass.side door of 2001 Dodge gr.caravan sport
1, Disconnect the able from negative terminal of the battery.
2. Pry the courtesy light from the door trim and disconnect the wire connector..
3. Remove all door trim panel retaining screws and door pull armrest assemblies.
4. Remove the door switch panel and the control switch panel and the control switch assembly.
5. On models with memory seats/mirrors, use small-flat bladed pry tool to remove and disconnect the wire.
6. Grasp the trim panel lift up and pull out to detach it from the door. Disconnect the inner door handle lock rod from the handle. Unplug any electrical connectors remaining and remove the door panel.
7. To install, connect the wire harness connectors and place the panel in position in the door. Press the trim panel down into place until the hooks are seated.
8. Install the armrest/door pulls, the courtesy light and the window switch'
9. Reconnect the battery
Also. You will need star pattern drivers to remove the window and motor from your door. If you have all the equipment it should only take you 1 hour.
SOURCE: Power window on 2001 chevy silvrado
Sounds like your gears are striped out inside the motor. I had the same problem on a car of mine. I just went to a parts store and bought the gear and took the motor apart and fixed it myself. It cost 18 dollars with tax.
Good Luck.
SOURCE: remove inside passenger rear door panel 2001 Chevy Tahoe
I would try to test the ground the motor first, also you can duplicate the ground with no consequence. If the motor is real dirty/ dusty, you may be able to clean it and ck the brushes in it while you are there.
SOURCE: 2003 Dodge durango sport all four power windows not working
I know its not what anyone would want to here but sounds like a short. Best thing to do is first wiggle your key switch when the vehicle in in the on position then at the same time try to check to see if locks or windows are working. Then do the same in while the rig is running. If that dont work your ignition is fine and you need to take off door panels and check and wiggle all conections on window motors and lock motors and look for melted or burt wire or some that might have got hot. If all is good there you need to go to the back of the fuse box were the fuses to those items plug in and check there. As far as the service engine light goes either take it to the nearest Schucks or AutoZone and they will check it for free if not cycle the key on and off 3 times and on the 3rd time leave it in the on position look at your odometer light and it will flash a code remember that code and type Dodge then the code on yahoo search and it should tell you why your light is on Hintz whay sensor is bad. Hope this helps.
