Welcome to FIxYa.com
REMOVAL AND INSTALLATION Remove in the order shown in the figure. Install in the
reverse order of removal. I Image 1. Nut 2. Lock washer 3. Bolt 4. Nut 5. Nut 6. Lock washer 7. Bolt 8. Nut 9. Washer lo. Nut 11. Lock washer 12. Bolt 13. Rear propeller shaft Propeller shaft (4x2) Before removing the propeller shaft, mark the flanges for
correct installation. Propeller shaft (4x4) Before removing the propeller shaft mark on the front, and
rear side flanges for correct installation. (4x2 Model) When the propeller shaft is removed from the extension
housing, immediately install the SST into the extension housing to prevent oil leakage B2200: 490259440 B2600i: 49 5120 440 1m a Propeller shaft 1. Align the marks. And install the rear propeller shaft. Tightening torque: 49-59 N.m (5.0-6.0 m-kg, 36-43 ft-lb) 2. Install the center bearing support assembly. Tightening torque: 36-53 N.m 3.7-5.4 m-kg, 27-39 ft-lb) 3. Align the marks, and install the front propeller shaft. Tightening torque: 49-59 N.m (5.0-6.0 m-kg, 36-43 ft-lb)
Thank you for using FixYa.com
Regards, Lee Davidian
