Nikon D80 Digital Camera with 18-200mm Lens Logo
A
Anonymous Posted on Aug 16, 2014
Nikon D80 error message - Nikon D80 Digital Camera with 18-200mm Lens
  • kakima Aug 16, 2014
    Any particular error message?
5 Related Answers
Anonymous
  • Posted on Mar 17, 2009
SOURCE: Nikon DSL D80 with "r02" error
normally, just removing the lens and putting it again you solve the problem. F-- problem means "there's no lens attached !"
Anonymous
  • 7 Answers
  • Posted on Jul 05, 2009
SOURCE: fEE error code on nikon d80
To solve this all you need to do is turn the lens' aperture ring (the one nearest the camera body) to the smallest number (probably 22 or 32).
Anonymous
  • 11967 Answers
  • Posted on Aug 28, 2009
SOURCE: Error Message with Nilon D80
Have you been to the Nikon website to check for firmware updates?
Anonymous
  • Posted on Nov 26, 2009
SOURCE: Nikon D80 'error' and 'clock' message
La batería del reloj
El reloj de la cámara funciona con una fuente de alimentación independiente y recargable que se carga si lo necesita
cuando la batería principal está instalada o la cámara se alimenta mediante un Adaptador opcional de CA EH-
5. Dos días de recarga proporcionarán al reloj la energía suficiente para aproximadamente un mes. Si parpadea
en el panel de control, la batería del reloj está agotada y el reloj ha vuelto a la hora de inicio,
2006.01.01.00:00:00. Ajuste el reloj con la fecha y la hora correctas.
Anonymous
  • 181 Answers
  • Posted on Jan 04, 2010
SOURCE: err message appears on the display of my D80.
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
Error message on nikon d80
The ERR message indicates a camera malfunction. In my D-90 manual it says that it can be cleared by releasing the shutter. The only way to do that is to turn the camera off and back on. Rarely, that won't work and you have to remove and reinstall the battery.
The manual also says that it this have frequently or persist to contact a Nikon authorized service center. I would contact Nikon tech support at www.Nikon.com and discuss the problem them before contacting an authorized service center.
Error Message for D80 Camera
Please, help us help you. What is the error message? If it is FEE then set you lens to the minimum aperture such as f/22. Being as you have not provided us the error message anything else is a guess on our part.
When I put on the D80 Nikon camer with 18-55 lens showing err 10 or 11 in small display in place of frame counter. Otherwise auto focas work, even camera klik but picture not expose then what is the...
Hi nrkelkar, In the D80 manual page 36 it speaks about the buffer. What you see as an error message is r with a number. The number is how many shots the buffer at that moment can handle. It is not an error message.
Error message on D80 Nikon
To assist you we need more information than you provided. For the ERR message read page 132 in the D80 manual.
My nikon camera keep got error and dont have the
You have not provided enough information, what is the error read? If it shows ERR then: The ERR message is not a good thing. Read page 132 of the D80 Manual. Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work call Nikon digital 1-800-645-6689.
1helpful
Nikon D80 error message rEE
2answers
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
