My computer does not have wi fi and i can't get mail on my iPad but i can still get netflix. why is tha.? I thought you needed internet connection to access netflix on iPad
Can your computer connect to the internet? If it can, it just means that you have a wired internet connection and not a wifi connection on the computer, which means your iPad is just connected to your home network via wifi. If your computer can't access the internet or you know you don't have internet service at home, then you either have cellular service (3G/4G) or your iPad is connected to some other available WiFi from someone else's service.
SOURCE: my wi fi is not connected. How do I do that/
I picked 1 up for the first time and connected in 2 minutes.
In settings page where you add a wireless connection, you will need to know..
Security type, mine was wpa2 ( may be wpa/wpa2/wep)
SSID, your network name that is transmitted, mine was default
password, whatever the wireless password you chose with wpa, if you have wep, it gives you a pass key, you will need to log onto your router to get this
SOURCE: my iPad cann't connect to gmail
If you have the iPod software 2.2 or 2.2.1 you shouldn't need to set it up as "other." It should already be there along with the Microsoft Exchange, MobileMe, Yahoo, AOL options. All you need to enter to finishing the setup is your full name, email address, password, and a description of the account if you wish.
SOURCE: cannot connect to my Wi-Fi
Need more info. Is your router broadcasting? What is the security setting. Cruz Reader has a menu icon at top (looks like a circle with horizontal lines). Click on it and go to the bottom of the screen on right side and hit settings. Network is the first line. Press on it an d see if wireless on cruz in set to on. If not turn on, if on see if it sees any wireless in your area. If it does not then first thing to do is to make sure your router is broadcasting. If you see other routers and do not see your routers name then you must check to make sure you router is set correctly. Even if you have security it will still show up in the cruz reader if it is set up and broadcasting. If security is set then you either have it set as WEP with a paraphrase in you router that points to key phrase No:1. You can find this out by typing the setting of the router wihich is usually 192.168.1.1. You must go into the router with this address and copy down the Key Phrase in number one, if set up this way. This phrase will be necessary if you have security. If you have not security, and you are broadcasting you should be seen. There is more but this should get you started.
SOURCE: the combination fn+f8(the wi fi button ) is not working
nothing you can do about it ... if you dont use the wireless you can disable-it from bios and the light willl shut down....
i have the same laptop ..and except the battery that goes fast it's a reliable laptop
PS you would better use w7-x86/32 bit and it will performe better
