iLO IWT3206 TV Logo
L
Lisa Payton Posted on Aug 16, 2014
Why does the picture on my iLO only show up horizontally in the middle of the screen? What can I do to make the picture fill the entire screen vertically and horizontally?
I have an ilo model number IWT3206. The sound works fine but the picture will not fill out the screen from top to bottom and is approximately 3 inches in width. The picture length does reaches from side to side completely but the picture is extremely narrow. How do I fix this??
1 Related Answer
Anonymous
  • 126 Answers
  • Posted on May 15, 2009
SOURCE: My ilo tv picture is 1 1/2 inches. How can I fix this??
its a vertical problem could be bad cap or possible vertical i.c. okay take to tv shop is their still a warrany on this set sounds pretty new shad
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Horizontal is flickering
flickering as the picture becomes smaller and bigger or are there lines showing up? Please describe it better if you can so I know exactly what you are seeing. Any color changes?
Ilo plasma slow picture display, a few pixels at a time and no sound
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Horizontal Line through middle of TV screen
This is usually a bad elect capasitor or a bad solder connection on the vertical IC, The capasitors will be close to the vert chip..Sometimes you can clear problem with a light tap on the TV, if so then suspect bad solder.
Charlie
2helpful
2answers
Sony rear projector TV problem, KP-61v35
This is a problem with the vertical circuit. This can be as simple as poor connections at the vertical IC or a defective IC. If you can solder, you should be able to fix this yourself. Let me know if you wish to attempt the repair and I will supply additional details and instructions.
Dan
2helpful
That sounds like simple ring-cracks in the vertical circuit, most likely the vertical Ic itself... On the printed circuit side of the Tv look at the vertical Ic and examine it carefully under some magnification where each pin of the Ic solders to the board. See if you can find any cracks in those solder connections.
Bill
6helpful
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
7helpful
4answers
Ilo 42" plasma tv model#pdp4210ea1
my 42" ilo plasma started going black on the outside to middle, now its totally black and no sound the power indicated lites for a min then the tv shuts off
Top iLO Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
