2000 Chevrolet Venture Logo
Posted on Aug 16, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Flickering lights lights are flickering
ray012965
Level 3:
Master:
  • Master 453 Answers
  • Posted on Aug 16, 2014
ray012965
Master
Level 3:
Master:
Answers
453
Questions
0
Helped
166780
Points
1016
This is usually caused by a fault in the alternator replacement recommended usually the internal regulator should regulate voltage between 14 to 16 volts of direct current.it may be delivering 17 or more causing lights to actually brighten this can also damage your battery have it checked at an auto store its usually free
What would make my Chrysler 300 2006 headlights and brake lights flicker
usually a bad connection, loose wires or could be switch
https://www.youtube.com/watch?v=O6JL7ZTkSmc
https://www.youtube.com/watch?v=7CYXy-CJ-f0
The guy in the video below changed switch and lights still flickered. He said while switched was unplugged he cranked his car and lights came on and did not flicker but when he plugged the switch in they flickered. He took new switch back to dealer got another new switched and lights worked. You might unplug switch, crank car see if lights stop flickering.
https://www.youtube.com/watch?v=fGmmrHYMLHY
All lights flicker on my 1998 mystic
I wonder if all the lights flicker?
Some headlight bulbs aren't held into the reflectors as securely as others and can appear to flicker due to vibration, bumps and so forth. In this case the other lights will not flicker. A similar effect can happen when the bulb connections aren't positive.
If all the lights flicker it must be the voltage that is fluctuating due to poor wiring connections or a fluctuating charge rate/alternator performance.
2006 corolla se dashboard lights flickering
If all the lights are flickering. I would suggest that you only go as far as locating the fuse. Clean it and put back. Alternatively replace with new fuse. It's unusual for all lights to flicker. 1 might flicker, indicating a faulty bulb. On Toyotas, the dash lights are usually on the same fuse as the park lamps.
Bought a new alternator due my old one FAILED the test. But, I still have the problem with my head lights flickering & stereo going off then on when I accelerate to go.
Diagnosing Common Automotive Charging System Problems
www.onallcylinders.com/.../diagnosing-some-common-charging-system-...
Sep 18, 2013 - Flickering gauges. ... Problem: The charge indicator light flickers while driving. .... My alternator has been replaced for the third time in 5 months. ... I bought a new regulator but it is still doing the same thing... .... my headlights wont turn on, car runs fine when jumped, battery last for maybe 3 hours, any ideas ...
All lights Flickering/Pulsating only when motor is running ...
www.cadillacforums.com/forums/cadillac-forum/t-221843.html
Feb 11, 2011 - So i have noticed for a while now that all my interior lighting (radio, tach, even ... Installed the battery and have not had issues starting since then. ... So now ipurchased a new alternator "just in case" figuring i would eliminate the .... Interior lights and headlights still seem to pulse/flicker while idling the most, ...
Lights Flickered. Replaced Alternator. Now more flicker? - Camaro ...
www.camarozone.com/.../lights-flickered-replaced-alternator-now-more-...
Apr 22, 2013 - 20 posts - ‎4 authors
Lights flicker
check ground locations in harness under hood ,make sure they are tight
My hazard lights and flicker lights are on, but not flickering. what can i do
I assume you mean your signal lights when you say flicker lights? Your problem could either be a bad flasher unit or bad bulbs. I'd put my money on the flasher unit since none of the bulbs are flashing.
Lights flickering
If the light is flickering and not just becoming brighter or dimmer with engine rpm, I'd suspect an electrical short, possibly between the battery and alternator or inside the alternator itself. have the alternator output checked before going further with diagnosis and before it fails completely and becomes more difficult to diagnose.
Flickering lights alond with the engine!
it sounds like the voltage regulator is faulty.........it is integrated into your altenator so you will want to have your charging system checked
hope this helps!
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
