Your best option may be first to transfer the data from the internal memory to a PC using the USB storage feature of the phone. For this it might be better to install the LG software on your PC first.
Then insert the 8gb SD card and if it is already formatted copy the files from the PC to the phone.
For better guidance refer the manual available from this site.
Product Support
This also has the software you will need on your PC.
Follow instructions on topics on transferring files.
SOURCE: Lg lp500 cookie mobile wont store automaticaly into memory card
Hi, with the Cookie you have to set your camera and video settings to external memory seperately, even though you have already made external memory your primary storage....its weird! I don't have the phone with me right now to check but open up the camera by clicking the button and while the icons are on the screen tap the one that looks like a cog, this takes you to the settings page for the camera, under one of the tabs here you will see two memory type options. Tap the 'external memory' option and away you go! You need to do the same with the video settings.
SOURCE: 8gb micro sd card does not work. lg vu cu920. is there a fix
I HAD THE SAME PROBLEM AND KEPT ON MESSING WITH THE 4G MEMORY CARD AND FOUND OUT THAT I HAD TO FORMAT THE MEMORY CARD ON MY COMPUTER AND NOW IT READS THE CARD..ON THE SIDE OF THE SD ADAPTER HAS A SLIDING PIECE THAT SAVES YOU FROM DELETING THINGS ACCIDENTALLY BUT IF YOU SLIDE IT INTO THE MIDDLE POSITION THEN IT WILL ALLOW YOU TO FORMAT THE MEMORY CARD BUT YOU WILL LOSE WHATEVER THAT IS ON THE MEMORY CARD AND WILL HAVE TO DOWNLOAD IT ALL OVER AGAIN..I HOPE THIS IS CLEAR ENOUGH FOR EVERYBODY TO UNDERSTAND BUT THIS IS HOW I GOT MY MUSIC AND PICS ON THE MEMORY CARD
SOURCE: I cannot play music off my sd card on my lg banter phone
i think you need to re-program your phone
i hope in can help you
SOURCE: my phone wont read the micro sd card
Check wheteher the card is nor micro SDHC, you r device supports only SD cards , if its SDHC then your device wont ablt to read it
SOURCE: codes for formatting memory card
i have memory card m2..i have sony erriecson moblie k770i it need code to formate card.. what is the code can u help me.
