Question about Whirlpool Washing Machines
What does F11 error message stand for on my Whirlpool awo 9565 washing machine?
I own a Whirlpool AWO 9565 washing machine. Once I choose a program, lines start blinking on the panel for a few seconds until the "F11" error message shows up. It also makes a rhythmic sound like a clicking of some sort while blinking. If I turn the knob to a program, it seems to start automatically without me pressing the start button. What is wrong with my machine? Ps. I can't find the manual anywhere.
  • Whirlpool Master
  • 5,420 Answers
The F11 fault code indicates a serial communication error between the Machine Control board and the Motor Control board. This can be caused by several different problems.
A failed Machine Control board could be failing to provide the Motor Control board with proper voltage. If this is causing the F11 code, then the Machine Control board would need to be replaced.
The Machine Control board could also be failing to supply proper voltage to the door lock assembly. The Machine Control board would need to be replaced for this failure as well.
Voltage flows from the Machine Control board to the Door Lock Assembly. The Door Lock then energizes and closes the Door Lock MAIN Switch. Voltage flows out of the Door Lock Main Switch to the Motor Control board. So if you have power into the Door Lock Assembly but not out of the Main Door Lock Switch, it will give you an F11. If so, you will need to replace the Door Lock Assembly.
You could have a bad Motor Control board that is causing this failure. A bad wiring connection between the Motor Control board and the Machine Control board could also cause this fault code. A bad wiring connection between the Motor Control board and the drive motor is also a possible failure. A failed drive motor could also cause the F11.
With so many possible causes for this failure, I recommend calling a service technician to diagnose and repair the problem in your washer. If you are able to unplug the washer and check the wiring connections, you may be able to find a loose wire harness connection that is causing the problem. Much of the diagnosis for the potential problems noted above requires live voltage checks. I do not recommend conducting these types of checks yourself. Unless you want to take a chance and replace the Machine Control board and the Door Lock Assembly,
Posted on Apr 04, 2015
SOURCE:
SOURCE: Whirlpool AWO 3761 washing machine.
what does it mean when fh comes up on washer
Posted on Apr 11, 2010
  • 343 Answers
SOURCE: i have a whirlpool awo 3751 washing machine when i...
You most probably have a faulty water inlet valve...Not an uncommon problem..They can sound ok, but when you check the detergent drawer there will only be a trickle..Replace the inlet valve...Good luck...Nomess
Posted on May 24, 2010
SOURCE: Whirlpool AWO/D 7740 error code F23
error code f23
Posted on Oct 17, 2010
  • 6277 Answers
SOURCE: Whirlpool AWO/D4305 Washing Machine. The "Water
Providing that the tap is turned fully on AND the hoses are not kinked or squashed at the back, this is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs a service call ;-0(
Good luck,
John C
Posted on Mar 27, 2011
  • 6277 Answers
SOURCE: Hi. My Whirlpool AWO 5761
Whirlpool 'F09' states 'overflow' meaning that it has sensed water in the bottom tray where a lot of the electronics are. That is why it will not continue- for its own safety effectively.
Have the back removed and see if there is actually water there. If so possibly a hose/connection is leaking. If not then the sensor is malfunctioning ;-0(
Good luck,
John C
Posted on Apr 08, 2011
HOW TO REPLACE WHIRLPOOL WASHING MACHINE VALVE MAGNET for AWO/D8500
Do not attempt to just replace valve components this is not a proper repair, just replace the complete inlet valve
Nov 16, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Service light on awo/r5206 washing machine
Resetting the washing machine: Follow these tips, click on: Reset
Jan 20, 2013 | Washing Machines
Whirlpool washing machine AWO/D 5556 washing machine service light showing ?
The warning light comes on because the machine "thinks" that something is wrong. Since it stops on and off something is wrong.
Why not phone the Whirlpool service in your area and tell him aboout this and ask what you can do??
give it a try
Kolbrun
Feb 22, 2012 | Whirlpool Washing Machines
How to replace belt on Whirlpool AWO/R4205
Please find tips from the link below on how to replace belt.
click on Washing machine belt replacement
Nov 11, 2011 | Washing Machines
WHIRLPOOL AWO/D 8500 WASHING MACHINE DOES NOT PUSH THE WATER THE OUTSIDE OF IT
WHIRLPOOL AWO/D 8500 WASHING MACHINE DOES NOT pullTHE WATER THE inSIDE OF IT
Feb 08, 2011 | Whirlpool Washing Machines
Washing Machines Logo
138 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
