Question about Konica Minolta Office Equipment & Supplies
How to remove error C0200 on bizhub c350?
I tried to reset with the micro switch in the front under the imaging unit but still error persist.
  • 210 Answers
C0200 - Cyan PC Drum Charge Corona Malfunction. Did you mess with this imaging unit? You won't be able to reset if the malfunction is still present.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Posted on Aug 21, 2014
SOURCE:
  • 24 Answers
SOURCE: Bizhub c350 will not scan to hdd
Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
Posted on Jun 25, 2009
  • 5 Answers
SOURCE: Konica Minolta C353 has a C4551 error, how do I fix it?
try replacing the imaging unit with a new one not a reset imaging unit
Posted on Sep 02, 2009
djklermund
  • 3 Answers
SOURCE: c350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
Posted on Oct 18, 2009
  • 15 Answers
SOURCE: Replacing Image Transfer Roller Unit & Paper Dust/Ozone Remover
hi this unit located in the RIGHT DOOR
Posted on Jan 15, 2010
copyalbania
  • 96 Answers
SOURCE: how to reset the copier after installing the
Normally it has no need for reseting.
In the moment you put the new image unit it resets the counter life, although you can reset by holding down the trouble reset button and in the screen you will see trouble reset.
touch it and switch in and off the machine with the main power button.
Posted on Aug 13, 2010
How to remove error C0200 on Minolta bizhub c350?
Aug 15, 2014 | Konica Minolta Office Equipment & Supplies
Error code c0200 minolta EP 4000
Sir, right below the drum area when you open the machine front door is a assy. with two very fragile gold plated wires that transfer the image from the drum to the paper. The paper moves over this wires during the copy process. They mite have broken giving you a C0200. Or the same type of wires are above the drum on the drum unit which must be removed to see them mite be bad. did you open close the front door to see if the machine will reset?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 25, 2014 | Minolta EP4000/5000 CS/PRO Copier
MINOLTA C350 ERROR CODE C0200
Cyan image unit replace it. Reset code by opening and closing the front door. Also try reseating it.
Jan 15, 2013 | Minolta C350 Color Printer/Scanner/Copier
How to reset image unit for C350 bizhub?
well there is a chip on the image unit that image unit (all colors) you need special chip writer to reset. you may need to just buy a new unit or drop me a line i may be able to get one...
Oct 27, 2011 | Konica Minolta bizhub C351 All-In-One...
How do you clear error code on a bizhub C350. A piece of paper was fused on the fuser unit and we were able to get the paper off. Now we have no access because the panel is locked.
while powering up machine hold down utility/counter key until trouble reset appears on screen. select it and ok should apper under it. power down machine for atleast 10 sec and turn machine back on.
Jul 22, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Error code c0520 konica minolta c350
How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521).Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Jan 18, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
C350 bizhub image unit counter won't reset after changing
using a post:
So all settings are RESET.
thanks for krishmaqvan
Dec 29, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
How do you do a hard reset on a Bizhub c350? Thanks.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Mar 10, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
169 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
