A
Anonymous Posted on Aug 15, 2014
What is error sc322 - Lanier Office Equipment & Supplies
quennie732
Level 2:
  • Lanier Expert 422 Answers
  • Posted on Aug 23, 2014
quennie732
Lanier Expert
Level 2:
Answers
422
Questions
0
Helped
236129
Points
775
Laser sync error, bad mirror motor?
ERROR 322 IS DISPLAYED ON MP161 SPF
http://terraofficesolutions.com/forum/index.php?topic=27.0
Quoting from web page shown:
Ricoh Error Code 322, SC322 Fix - Printer, Copier, Fax Machine « on: October 01, 2012, 07:40:17 pm »
The Ricoh copier error code SC322 or 322 is a laser synchronization problem.
This error code can mean:
Bad LDB
Bad IPU Board
Bad Controller Board
Bad Detector Board
Check the wires between I/F and Detector.
After the polygon motor reaches standard rotation speed and the LD unit fires for 400 ms, the laser synchronization detector does not get a signal.
• wires between detector and I/F disconnected or bad
• Detector is installed incorrectly
• Detector board is bad
• IPU board bad
To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
If the problem persists you may need to contact a local service technician to take a look at your copier.
How do i clear code sc322 on nashua aficio 2016
THIS VIDEO SHOW HOW FIX IT
https://youtu.be/-DGnULMHtD4
Lanier LD118d showing a error sc322, how to fix
sc322 is an error with the copier's laser unit. You can pull the laser unit out and clean it up if there is toner on or in it, but more than likely either the polygon mirror motor or the laser unit as a whole assembly should be replaced.
2helpful
After sc326-00 my copieur ricoh aficio 350 put on his screen sc322-00 and not work, how cold i resolve this problem
Laser Synchronization Error(1 & 2)(sc322 & sc326)
· Laser synchronization detector board out of position
· Laser synchronization detector board defective
Also check if any cables are loose and also if the laser unit is dirty.-Clean it.
3helpful
Functional Problem SC322
Polygon mirror motor is bad. Sometimes you can put a drop of oil on the shaft, but at best is a temporary fix. You'll end up having to replace it. Good luck
SC322 on Savin 4035
Laser synchronization error. It could be just toner on the LD unit. Try cleaning and doing the Pitch adjustment. If that doesn't work , then either the unit itself is bad, or the Sync. Detector board.
***This will obviously require a tech.
8helpful
3answers
I need solution to aficio 200 error code sc322
sc322 is a Laser synchronization error:
Means that the laser synchronization signal cannot be detected by the main scan detector board.
Possible causes:
Poor connection of the interface harness which connects the laser synchronization detector board and the BiCU board.
Laser synchronization detector board out of position or is defective.
BiCU board is defective.
Unfortunately,unit needs service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1helpful
2answers
Lanier 5645 SC322 Error
It's most likely your Laser diode (LD unit). You're going to require a tech...see the posts the following link for the same problem. It's for a Ricoh model, but your machine actually is a Ricoh Machine (Ricoh owns Lanier), and is virtually identical to this one -just a generation older.
http://www.fixya.com/support/t1936988-sc_326_322_329_in_af2045
Ricoh AP2600 printer gives an error message of SC322
1st Laser synchronization error signal error. The 1st Laser that turns on inside of the printer can't synchronize properly to print out documents which is why this message comes up and nothing is printing. Probably is going to need to be replaced but a qualified service tech is going to need to look at it further.
Top Lanier Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
