Sony Ericsson XPERIA X8 Cell Phone Logo
A
Anonymous Posted on Aug 15, 2014
Memory card is not displaying its contents - Sony Ericsson XPERIA X8 Cell Phone
My nikon coolpix 7000 memory is displaying only 40 pics but is telling me the memory is full
Try copying the contents of the memory to the media card, then set the camera up so that images are saved to the card in future.
How do I view the photos in the memory card on my MacAir
2 ways.1. open the memory card and select the correct folder and the photos are in there. view with preview or quicklook (select the all then press the space bar) 2. open iPhoto, tell it to import picture off the card and view them there.
1helpful
2answers
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
14helpful
2answers
Fat alloc error
> FAT ALLOC ERROR
FAT == File Allocation Table (like a 'Table of Contents' in a printed book)
ALLOC == Allocation
ERROR == ERROR
Some of the contents of that 'Table of Contents' are invalid.
So, copy all the files from the Memory Card onto your computer, to save a copy of those files.
Burn a CD/DVD disk with a copy of those files.
Then, "reformat" the Memory Card, to write a "new" and "empty" 'Table of Contents' onto the device.
Then, copy all the files back onto the Memory Card.
Samsung C322 is not reading the contents of the memory card. On clicking Menu> My Files, the contents of phone memory is displayed but the contents of the memory card is not displayed. Tried...
Your phone may be not supporting memory card format... or your memory card may be password protected... connect your memory with your PC and format it other file format. how to format memory card, do the following. 1 insert your memory card in card slot of your laptop or card reader or your PC 2. open my computer 3 right click on the memory drive or icon 4 click on format 5 change your file system 6 click start.
After formating insert your card in phone hope it will work for you.
Please do inform about dis, thank you
Apr 21, 2011 • Cell Phones
How to access my files in memory card
connect the memory card to the computer using data cable... now you can see your memory card in MY COMPUTER.. now you can double click on the icon of your memory card in MY COMPUTER... the memory card contents will be displayed... now you can copy the contents in your computer for permanent retrieval in your PC or you can directly view them for temporarily retrieval....
My memory is connected through card reader in computer, "please insert a disk into drive f:" message will be displayed so pls help me and replymust
The "table-of-contents" on the memory-stick has become corrupted.
If you have pictures on that memory-stick that you want to "rescue", search online for "file scavenger" software.
If you think that the memory-card is "empty", put the memory-card back into your camera, and tell your camera to 'FORMAT' the memory-card, i.e., to initialize it back to the "factory" settings.
How do you move contacts from sim card to phone memory on a nokia 5530
check for option that displays what contents are displayed that is sim card or phone memory then in options you will have option to copy all sim contents to phone memory.
On problem
hi ,i used to have this problem but when i removed the memory card , copied all it's contents to my pc , format the momory and scan the memory contents for viruses then return the files again to the memory the phone works fine!!
if u still have this problem try another memory card.
i hope it helps.
Feb 03, 2009 • Nokia 7710
Help
Yes and in several methods as below listed. Since your posting refers to a generic problem for all digital cameras and not only an Olympus FE-230, some of the settings may have a different nomenclature or button name.
1. When you download pictures to you PC, rather than copy, select move; or
2. If you want to erase one picture at a time from the camera - press on the power button, then menu button, once menu is displayed, arrow down/up, you will be asked to erase the picture displayed, select yes/no by up/down, then press OK (menu button); or
3. If you want to erase all contents of the memory card of the camera - press on the power button, then menu button, once menu is displayed, arrow right, down to select card, right to select card setup, right to enter card setup, arrow down to select format or erase all, OK. Erase all just erases the files, format erases all and re-initialize the memory card; or
4. Remove memory card from camera and insert into a memory card reader attached to USB of your PC. The memory from the camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
5. Connect the camera via the supplied cable to any USB port of your PC. The camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
Specifically for an Olympus FE-230:
1. Press the < or > buttons to display the picture you want to erase;
2. Press the trash can button (bottom right);
3. Press the UP button to select [YES], press OK;
or
To erase all:
1. Press the MENU button to display the top menu in playback mode;
2. Select [ERASE], [ALL ERASE], and press OK;
3. Select [YES], and press OK
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 08, 2007 • Cameras
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
