Whirlpool Duet Sport HT WFW8400TE Washer Logo
A
Anonymous Posted on Aug 15, 2014
What is whirlpool error code 21 - Whirlpool Duet Sport HT WFW8400TE Washer
1 Related Answer
Anonymous
  • Posted on Apr 26, 2010
SOURCE: f-21 error code?
have an error code f/33
2answers
What does F1 error mean and can I "fix" it myself?
What are you working on? Please be as specific as possible with a manufacturer & model number if possible, we can much better assist you once we know exactly what you're having a problem with! Thanks, let us know!
My washer whirlpool duet steam has a code of F 21 what does that mean
The Whirlpool washer error code F21 means the washing machine has a "water draining issue", meaning the drain pump itself, or the drain hose is clogged and the washer is having problems draining the water out
2answers
My washer has the code F 21 can you tell me what the problem might be??
I'd check owner's manual, or Mfg web site for your model.
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Whirlpool Cabrio Washer Error Codes & Repair Help
applianceassistant.com/Washer.../Cabrio-Bravo-Oasis-Error-Codes.php
Whirlpool Cabrio Washing Machine Error Code Problems, Diagnostics, ... Cabrio LdError Washer is taking too long to drain water from the washtub
Kenmore Elite Calypso Top Loading Washer - ApplianceBlog
www.applianceblog.com/.../1297-Kenmore-Elite-Calypso-Top-Loading-...
Sep 11, 2005 - 10 posts - ‎5 authors
My washing machine stopped after filling and won't wash, drain or spin. ... and then come up with either LD, FL Or SL code and stop working.
Whirl Pool Cabrio LD Temp fix pt.2 - YouTube
? 2:59
https://www.youtube.com/watch?v=tFBtD2wUj4g
Jun 21, 2009 - Uploaded by liquid131
Whirl Pool Cabrio LD Temp fix pt.2. animal131 ... How to override an error code on the Whirlpool Cabrio washer - Duration: 3:08. Whirlpool ...
Whirlpool f08
whirlpool f08
f08 e03 error codeF8E2 is DISPENSER SYSTEM ERROR - Dispenser motor is unable to reach the desired position. Possible causes: Check the mechanical linkage from the dispensor motor to top of dispenser. See TEST #12 (Dispensor Distribution System) on page 21. Someone else can post to contents of Page 21. Good luck.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTou7Nz
Yes, it is a dispenser system error. The technician manual says to check the mechanical linkage from dispenser motor to top of dispenser.
However, in my case this page from whirlpool was helpful:
https://www.whirlpool.com/product-he...r-code/PH5260/
It says a common solution for this error (f8 e2) is:
The detergent drawer or detergent cartridge might be clogged with detergent. Clean out the detergent cartridge per Use and Care Instructions.
If cleaning the detergent cartridge did not correct the problem, please contact us.
For any additional questions, please call our Customer eXperience Center toll-free at 1-866-698-2538, Monday through Friday 8AM-8PM Eastern Standard Time.
You will be asked to provide the model and serial number which is found on the front door rim after opening the door.
So I washed out my dispenser and now it's working again.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTzjNdt
1helpful
What does f-21 mean?on my front loader washer
Please check this video on abut f 21 error code and how to rectify it.
Code reading f 21, whirlpool, front loader, washer, duet sport
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
1helpful
Error code F 21? washer stops
Hi
The error code F21 means LONG DRAIN
NOTES: After 4 minutes the “Sd” error will be displayed, and then 4 minutes later the “F/21” error code will be displayed. Press PAUSE/CANCEL two times to clear the display.
1. Check the drain hose and make sure it is not plugged or kinked.
3. Check the electrical connections at the pump and make sure the pump is running.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
13helpful
2answers
Whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
