Question about Plumbing
Installed a new KWC Domo faucet and its leaking (alot) under the sink
Installed a new KWC Domo faucet and when I opened up the supply lines it was fine but when I pushed up the handle for water it poured out under the sink. No water came out the faucet just under the sink a lot..
  • 739 Answers
Does if have a sprayer and is it still hooked up?
Posted on Aug 28, 2014
SOURCE:
  • 49 Answers
SOURCE: Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Posted on Sep 20, 2009
  • 54 Answers
SOURCE: leaking under sink and st base on sink
Remove spray head then faucet tighten connection on the spray hose
Posted on Sep 26, 2009
motor1258
  • 6674 Answers
SOURCE: moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Posted on Dec 29, 2009
  • 17 Answers
SOURCE: Sticking of KWC DOMO model faucet.
I would definitely take it apart to find out what is causing it to bind, that is not normal. Make sure that you turn your water supply lines off under the sink, via angle/strait stops. From under the faucet there is one or two nuts fastening the faucet to the counter, they are usually screwed on just a little more than hand tight. The problem may not be fixable, so be prepared to replace the faucet.
Posted on Mar 19, 2010
Just received the new part for the domo. My model is older and is chrome with black. I have removed the top screw and need to know what is the next step in taking apart the rest of the faucet so I can replace the new part # k.32.60.00
Thank you, Stuart
Posted on May 29, 2010
Price Pfister Marielle, 26 series, leaks around the top of the spout body when water is turned on. How do I take it apart and fix the leak?
1 under the sink turn off both water supplies
2 disconnect the supply lines at the on/off valve EZer than at faucet
3 under sink unscrew the retaining nut(s)
4 on top wiggle or pry the faucet and lift up and remove.
5 know you can replace the spout and don't forget the new O ring that's why it leaks anyway. you really just need the new washer O ring .
6 Reinstall check for leaks
7 caulk around faucet.
Hope this helps Mike
May 31, 2018 | Price Pfister Plumbing
My KWC Domo faucet leaks when pull out is in spray mode is this an easy fix
Probably needs at least one new rubber seal, you'd probably contact your supplier.
Various spare parts are shown in this manual (attached):
Jul 10, 2016 | Plumbing
New kwc domo leaking under (alot) sink
mixing chamber of the faucet may be cracked
Aug 14, 2014 | Plumbing
Kwc faucet washers
lowes home improvment
Dec 11, 2017 | Plumbing
My husband installed a new KWC Domo faucet in our kitchen yesterday. When he was finished, he turned the faucet on and got a trickle of water. We are stumped and the instructions are no help.
Take off the aerator from the spout (it just screws on, and should not be so tight you need a wrench) and then run the water. You'll probably find the aerator screen is clogged with debris and you can wash it off. This often happens when you turn the water supply off to connect the new faucet. After you clean off the aerator and screw it back into place your new faucet should work fine.
Feb 27, 2011 | Microwave Ovens
KWC Domo single handle faucet is sticky...how do I fix that? Do I have to replace a cartridge?
Have the same issue. No one seems to have an answer, including KWC (except to buy a new $90.00 cartridge).
Nov 09, 2010 | Danze D403412 Melrose Single Handle...
Thank you, Stuart
May 11, 2010 | Delta Model 470: Signature Kitchen...
Mar 19, 2010 | Delta Model 470: Signature Kitchen...
KWC Domo faucet sprayer won't switch between spray and stream
Having installed and fixed kwc domo faucets for years I'd probably take the spray head off of the hose, then look into the bottom of the spray head and see if the check valve is still there. It probably is. I used to use a thin screwdriver to pry the check valve out out.It will come out. You need to work at it a bit but these hold back a lot of water pressure and catch any crud coming down the water lines.
TL
Mar 17, 2010 | Plumbing
How to install supply lines for Grohe k4 faucet
I hope this helps.
Step11Turn off the water supply. You'll find a shut-off valve under your kitchen sinkmag-glass_10x10.gif. Once the water is turned off, open up the kitchen faucets to allow the water remaining in the pipes to drain way. Step2Catch the drips by placing a bucket under the hot water supply line, located on the left side of your sink. Even a minimum of water can cause a mess and be potentially damaging. Step3Use a wrench to remove the compression nut that secures the hot water supply line. Let the disconnected section fall into the bucket. Use the wrench to loosen and remove the nut at the other end of the line and remove it as well. Step4Repeat Steps 2 and 3 for the cold water supply line. Step5Replace the cold water supply line. Hand-tighten the nuts on both ends, then use the wrench to tighten the nuts completely. Repeat the process with the hot water supply line. Step6Turn on the water supply and test for leaks
Apr 08, 2009 | Grohe 32.074.KD0 K4 Prep Sink Single-Spray...
Plumbing Logo
318 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
