Question about Element Electronics ELCHW261 26 in. TV
The elecricity went out television will not come back on
The television will not come back on
    Top Expert:
  • Element Elec... Master
  • 76,115 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Posted on Aug 15, 2014
SOURCE:
Hd72 had colorwheel replaced turned on and worked for about 20 minutes made a sizzling elecrical noise and went blank. Turned off disconnected and reconnected power and turned back on and no picture. ...
The power to the circuit board is passing through components that are breaking down. Eventually all function will cease and the unit will not respond at all. A power surge may have passed high voltage and current to the unit causing stress on the electronics inside. professional service can trace the circuit and find the damaged parts.
Feb 27, 2014 | Optoma HD72 Multimedia Projector
If you listen close to the tv it gives a strange noise when the volume is high
Youre more than likely getting elecrical "noise" or interference from a radio or cell tower. Get a quality surge protector, i have one made by Monster and it knocks out the interference.
Jan 15, 2013 | Televison & Video
Fuse #47 blowes on my 2000 focus all bulbs are good
it only means that your elecrical system on your running light was grounded thats why everytime you switch on the running light the fuse blown. The only solution to that is to find out where the line was shorted or grounded. you must start tracing it from your switch going down the elecrical line going to the fuse, relay and lights.
That's it, good luck then.!!!
Oct 01, 2012 | 2000 Ford Focus
4x4 doesnt work at all.no lights on the dash nothing.2001 s10 blazer can i fix this myself.looks like a corrided wie.tried it last year,she came back after i cleaned it up,but once i shut off the...
YOU MAST GET STEP BY STEP ON THIS PROBLEM TO RESOLVE FRST CHECK BATERY MEYBI YOU NIDED ANADAR VAN IF THIS IS TO OLD END CANT HOLD ELECRIC INSIDE .STEP 2 CHECK YOUR ALTERNATOR HIS CHARGING BATERY VEN MOTOR RUNING IF BROKEN FIX IT .3 CLEAN OLL ELECTRIC CONTACTS END INSURE GOOD GRAUND( - )POLE TO EVRY PART OF VECHILE DOORS ENGINE SHASHY EVEN THE DASH MAST HAVE GRAUND CONECTION YU MAST PUT THE DASH DAUNT TO CHECK EVRI LIGHT END HIS CONECTION DANGER:VORK SLOVLY TO IMPROVE CHIRCHUT.I THINK THE BIGEST PROBLEN IS VITH ALTERNATOR(BATERY CHARGER)-VISIT nedic@nikola.com for more help
Nov 08, 2009 | 1994 Chevrolet S-10 Blazer
Vespa ET4 125. Elecric start doesnt always engage properly.
- did you ever push the starter button while the engine was running?
if yes, the gear on the starter motor is damaged and needs to be replaced...
Oct 22, 2009 | Peg Perego Vespa Scooter
I need to replace the high pressure outlet on a k2-26m elecreic
if you contact Karcher they will tell you where your nearest supplier is located. try this link.
http://www.karcher.com/int/contact.htm
Sep 19, 2009 | Karcher K2.26 Electric Power Washer
Speaker too close to tv
the speaker will just affect your colours on screen, but not effecting your elecrical path. take your tv for service, it has a loose connection on a card. thanks
Sep 22, 2008 | Philips TS2744C TV
Odd sound from Samsung DLP TV
Buzzing could be related to the lamp/ballast connection. Try removing and reinserting the lamp look for arching marks on the contacts that would suggest that the connection wasnt good.
Mar 29, 2008 | Televison & Video
IPod and zune Short
I would recommend searching on www.avic411.com. I read lots of issues where certain ipods with specific firmware levels had issues. The good news is that most have some type of solution.
Mar 20, 2008 | Pioneer AVIC-D3 Car DVD Player
Element Electronics ELCHW261 26 in. TV Logo
52 people viewed this question
Top Element Electronics Televison & Video Experts
Steve Allison
Steve Allison
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
