Unfortunately, you are one of the lucky owners that has one of these things. You are going to have to remove the transaxle and break it down in order to replace the brake pad, "IF" you can find a replacement part! My suggestion is to double check the linkage and use you owners manual to see how you can or if you can adjust the linkage. Replacing the pad is not all that difficult but it is very time consuming. If you have to remove the transaxle to replace the pad, please be sure you have a breakdown list so you can disassemble and reassemble the transaxle correctly. You will need to find the exact model number on the transaxle and then look it up online and download a copy and print the breakdown section. Good luck.
SOURCE: What is the length of the primary mower belt for a
Many of the parts you can just drop the prefix and use the Sears /AYP #
So, look at the hood sticker or in your manual for the Husq#. 532 18 08-08 becomes 180808 which is a common Sears belt for their secondary belt on the newer 48.
OEP shows as a 5/8 X 89"
The primary for these 174368 (Engine to deck)OEP shows 5/8 X 90.
Best to get the oem if you can. Never tried aftermarket on these.
Also found THIS USEFUL INFORMATION.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: I have a YTH1542 husqvarna riding mower. Will not stay running
make sure the small vent hole on top of the gas cap is not clogged. Mine did the same thing and then I found mine was packed with dirt.
SOURCE: i cant replace the deck belt on my husqvarna ct151 lawn mower
The manual shows how the belts are put on, if you do not have one they may be purchased through dealers or small engine repair shops or online. On mine there is also a little diagram on the top of the mower deck. Another way to check is find an identical one that is functional and look at its belt. There are only so many ways it could fit and these are all made by just one or two manufacturers so there is not much variance.
SOURCE: need a belt diagram for
ttp://www.partstree.com/parts/dispdiagimg.php?src=r&ilFN=D%3A%5CEMPARTweb_52%5CCatalog+Data%5CEMP_IMG%5CHUS%5Cimages%5C90%5C35%5C0019.TIF&ilSC=10&ilIV=0&ilBR=0&ilIF=G&ilRE=8&ilSH=0&ilEG=0&ilRO=0&ilSC=23
