Question about Razor E300 Scooter
Problem putting the brake together on razor e300
  • 23 Answers
The brake adjustment is covered on page 5 of the user manual. There are photos of various band brakes here http://www.electricscooterparts.com/bandbrakes.html
What part of the band brake are you having and issue with?
Posted on Oct 27, 2014
SOURCE:
How to put air in tire of e300 razor
  1. rotate the rear wheel until the hole in the sprocket lines up with the tyre valve.
  2. insert the tyre valve extension through the hole and attach it to the tyre valve
  3. inflate the tyre to the correct pressure (usually 45psi)
  4. remove valve extension and put in a safe place for next time.
Inflating the rear tyre is detailed in the owners manual, which you can download from the Razor web site.
http://www.razor.com/au/products/electric-scooters/e300/
Jun 25, 2014 | Razor E300 Scooter
Tip
How To Lubricate E100 E200 E300 Razor Electric Scooter Chain Easy Way
<utube src="JKzj7Bu2Ink"></utube>This video will show you an easy way how to lubricate the chain on your Razor Electric Scooter. This process is shown on the E200, it should also be the same on the E300,and E100.
on Aug 03, 2013 | Razor E300 Scooter
Hi, after replacing rear tyre and putting everything back together the rear wheel seems to be stuck, it struggles to turn
probably bearings to tight take off wheel check axil see if it turns freely if it dont loosen up bearing screws untile it does turn freely reinstall
Jun 02, 2014 | Razor E300 Scooter
E300 electric scooter battery,
The scooter uses batteries specifically designed for deep discharge applications. If your new batteries are not lasting then they may only be suitable for standby or backup type applications like for your house alarm system or garage door opener when the mains power goes out.
Mar 19, 2014 | Razor E300 Scooter
Do UPG 12 volt 7ah batteries work as good as "RAZOR BRAND" Batteries?My scooter is an e300.Do you know if by chance,the e300 scooter needs razor batteries only?I got generic ones,and they are terrible
No. We get batteries from a local supplier and they work just as well. are by far the most common problem with razors because people dont keep them charged.
Hi there,My girls Razor E300 is a year old wont fully charge...
My guess is the batteries have gone bad. They only last about a year before they need to be replaced. You can buy them fairly cheap off of Ebay.
Jan 04, 2013 | Razor E300 Scooter
Razor e300 needs to be continually reset
Sorry it is really important to get your scooter put together and charged right away or it will get ruined Need new batteries
Nov 12, 2011 | Razor E300 Scooter
How to remove rear tyre from e300 electric razor scooter
  1. With a Phillips screwdriver loosen the two screws and remove the chain guard.
  2. With a 10mm wrench loosen the brake cable anchor and disconnect the cable.
  3. With two 8mm wrenches loosen the brake housing anchor and disconnect. (Keep the spacer and washers together.)
  4. With a 10mm wrench loosen both axle adjusters an equal amount. (roughly five turns)
  5. With two 17mm wrenches loosen the axle.
  6. Push the wheel forward in the slots to loosen the chain.
  7. Pull the wheel out. (Pay careful attention to the order the hardware is in there.)
Regards, Tomy
May 01, 2011 | Razor E300 Scooter
Need to have manuals e 300 razor scooter,need
http://www.razor.com/products/e300-electric-scooter.php
May 14, 2010 | Razor E300 Scooter
Razor E300 Scooter Logo
156 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
