Fedders A7DH45B2A Dehumidifier Logo
A
Anonymous Posted on Aug 14, 2014
Why does dehumidifier compressor goes on and off?
Fan runs and the compressor tries to kick on and there is a low grinding sound and then it goes off and the fan continues to run. The cycle repeats itself and the compressor never engages. It is not...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Dehumidifier (M7DH45B2A) runs but is not removing moisture from the air. The compressor goes on as does the fan.
heatman101
Compressor starts but no water goes into the chamber
heatman101
The compressor goes on but it never fills up with water
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Every time I plug my dehumidifier in to the ground fault plug the ground fault goes to failsafe. I tried another circuit and the dehumidifier didn"twork. I tested the outlets with aplug tester and they are...
You will find that the compressor is bad and will not start...this kicks out the receptacle.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Hi, My Silhouette 63pint dehumidifier does not ...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
heatman101
1helpful
No water is collecting on 2 year old lg humidifier
If when you turn your dehumidifier on the compressor runs then you should get moisture. Dehumidifiers work on the same principal as refrigeration. There is a bad control switch or the compressor start relay or capacitor is defective. If compressor runs and there is no effect then that is another problem. The filter should come out the front where the air goes in front and the filter should be washed by hand in warm degrease detergent water, dry and replace. If the disposable type filter I will help you contact LG.Thanks, Sea Breeze
Kenmore Dehumidifier Isn't Running
It sounds like you have power to the unit but a component is failing to start the system get an AC tech to check it.
1helpful
What terminal on the capacitor gets the blue wire from the run terminal on the compressor? Does it go in the terminal with the white wire or the blue wire?
Follow the start wire from the compressor to the capacitor, the run wire will go to the opposite side.
For instance if the white wire is the start wire on your compressor then the run wire will go to blue wire and vice versa.
KENMORE 70 PINT DEHUMIDIFIER
4681A20040R is the fan part #. Bought one on e-bay. Fixed the same problem.
Top Fedders Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
