0085,0082,0080.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: chunghop universal remote
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. - You can rate a solution with one of four
ratings as explained under (remember that at times a bit of to and fro dialogue
may be necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
SOURCE: codes for zenith univ. remote
You can d/l free Zenith remote manual (PDF) here:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=b8e8ed044c8bd982f885efd5f432012a&q=Zenith+ZEN100
Try these codes for JVC tv:
007, 108, 208, 308, 417, 502, 510, 617, 607, 702, 902
SOURCE: Remote control programming codes
i have a GE t.v. and just bought the RCA DTA800 converter box. none of the codes that were in the manual worked for my t.v. can anyone help?
SOURCE: RCA RCR 451 universal remote codes
www.rca.com/customerservice... click the find codes link.. then select your clicker's model number from the drop down box.
The problem is that it does not list the steps to program the remote after you have the correct code. Does anybody have this information?
SOURCE: rca big button universal remote
Go to: www.rca.com then .... accessories..... (On the left of the page) go to owners manual ..... also check for your code under .... code look up.... if your TV is not listed, use the search feature outlined in the owners manual
