I replaced the timing belt on a 2003 Hyundai Accent 1.6 engine. I'm having problems starting the engine. What are the steps to putting it back on time?
If by timing you mean that you aren't sure that you have the belt on the cam/crank assemblies properly, now is a bad time to mention it. This is an interference engine. Proper alignment of the crank/cam with the timing belt is critical and must be exact or serious internal engine damage will result. Even turning the engine too far without the belt properly aligned can damage pistons and valves. At this point if you didn't get it right, the damage is probably already done. For a quick check, disable the fuel pump, pull the spark plugs and perform a compression check. If it doesn't pass, take it all apart and assess the damage and repair as necessary.
