Drain cycle works fine but when slowing down loud noise. icheck the coupler and it is fine.
SOURCE: Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
It sounds like the bearings are going bad. Try spinning the drum with your hand while it is empty. It should spin nice and smooth. If the rotation feels a little rough and noisy, you might have a problem. You can double check by taking the drive belt off and try shaking the pulley. If there is "play" when shaking the pulley, the bearings are most likely toast. The inner stainless drum rides on two bearings which sit in the rear of the outer plastic drum. The whole plastic drum and bearings come as one piece and go for $150. It would cost about the price of a new maching to have someone come out and repair it for you. It sounds like kenmore has had a bearing problem which is pretty rediculous considering how much these things cost. Sears said, "those tend to go in a few years", which is criminal especially since the warrenty is usually conveniently exopired by the time this problem happens. If you are handy, have a spare day, and can remember how to put a washing machine back together, go for it. I did it and it was not a fun time. There is a lot of sharp metal edges in the machine so wear gloves. good luck
SOURCE: Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem.
worse case scenario is the transmission is bad, but this is unlikely.
SOURCE: Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
SOURCE: noise/not draining on spin cycle
I had that problem and it was the drain pump trying to drain but it coulsn't because it had lint, plastic, 3 underwires a looney some costume jewellery stuck in the pump. By the pump underneath you'll see a black plastic boot leading away from the pump. disconnect this and inside you'll find the lint trap and if you dig you'll probably find the culprit that stopping your pump from moving. Put it all back together and Voila!
