Need operator manual. Device works but no instructions
SOURCE: Clock
To set the clock - turn the radio off by holding the 'source' button(car's key still has to be on). Hold the 'function' button until something comes up on the screen. At that point you can toggle between options by pressing the 'function' button repeatedly and use the left/right/up/down arrows to adjust them.
Also SAT radio requires a separately installed tuner module. If this module is installed the radio ID code can be displayed by pressing the 'source' button until SAT radio is selected, and changing to channel 0.
SOURCE: How do I turn on the "external aux" for my pioneer DEH-p7000r
with your radio off ,press F button top right hand side it will prompt a menu once it comes up keep pressing the F button till it says aux on then sellect from the arrow up or down function below the f button it will toggle between on or off , sellect on and then turn off the unit your aux will work , dont know if the stregh of your ipod might be enogh though i tried ,and was very low. hope it works for you. cike3 PS, this menu alsow gives other options for this unit ,like the integrated alarm system
SOURCE: I can not set my car stereo's clock
Pioneer stereos clock setting
1)turn car iginition "ON"
2)turn stereo ON and then OFF.
3)Press SRC or Joystick until blinking clock appears
4)Set clock by pressing rt,left &top,bottom keys around volume knob (joystick).
i hope this helps.
SOURCE: Can't find ANY reference to ...
http://www.pioneerusa.com/pio/pe/images/portal/cit_11221/280476408DEH2800MPOperationManual.pdf
This is the 2800MP direct from Pioneer. If your unit is a 2700mp, was it purchased outside the US? This is the closest listing on Pioneer USA's site. Hope this helps.
