Same here Elliot 27 year copier tech look in owners manual sometimes simple codes can be found Their. With power on unplugg from the wall turn power switch of wait 15 seconds click you heels three times blow your nose and turn back on. If you have a real problem error will reaper. Today's copiers printers are so good with the A.I. it won't let you keep going if their is a real problem. Is the printer net worked stand alone or run by a PC? Call a dealer ask for the service dept. ask the they will usually tell what it means over the phone. Can't hurt to ask good luck. Bret
1. Check the transfer unit is set correctly.
2. Check the transfer roller is set correctly.
3. Check the high voltage supply board is set correctly.
4. Check the harness of the high voltage supply board.
5. Call a Ricoh Service tech.
transfer roller area leaking current. clean the area around it of devlp powder causing it to short to ground and change transfer roller and bushings. hope this helps
there could be following three possibilities
SC401 Transfer Output Abnormal
SC401- Transfer Roller Leak Detected
for more detail click
http://www.smilecopy.com/download/greske.pdf
hope it helps
if so, do rate the solution
Please open the front door and turn the blue lever in the middle,
remove the Transfer and Separation unit and check if the bushings of the transfer roller are damaged.
If OK, please give some oil on the shaft/bushings of the transfer roller. This unit may be replaced as a whole unit.
If SC401 re-occurs, please check the Photoconductor unit (drum).
SC401: Transfer roller leak error 1 SC402: Transfer roller leak error 2 -Definition- [B] A transfer roller current leak signal is detected. The current feedback signal for the transfer roller is not detected. - Possible causes - · High voltage supply board defective · Poor connection of the PCU · Transfer/separation unit set incorrectly
