C552 jam is at 11 it is cleared but still says its jammed
Then properly the sensor near the jam had it accurator jammed so the copier thinks there is still a paper there. or you mite have paper dust or dust blocking the sensor. Could also be a bad sensor worst case bad main board.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Clear Paper Jam error -- but there is no paper jam!
I have the same problem. Answer? PUt the piece of junk in the trash and never, never buy brother products again. I called Brother and they had a refurb for more than what it cost me originally!!!!!
SOURCE: paper jam
I have an HP 5510 All in one, and mine did the same thing. There was a plastic fingerlike thing that had hung up just to the right of the printhead, preventing it from moving. I removed the cartridge and managed to get the part unstuck with a screwdriver.
SOURCE: showing carrier is jammed. no paper blocking it.
Showing carrier is jammed. no paper blocking it.
SOURCE: paper jam message does not clear
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takiqq14
SOURCE: My canon MP620 Paper Jam Pull out the Jam Paper Al
There are pieces of paper stock on the sensor, when the paper jam happened then you pull out the paper did you get the whole page of the paper or have missing pieces? open the paper guide, turn off and on the printer and observe the unusual objects in the roller, this error is caused by objects in the sensor.
