The calculator is set for fraction answers it needs to be decimal point answers
SOURCE: Changing result display from fractions to decimals
Struggled with this and found answer on about page 19 of the instructions on the Internet. Answer also appear on paper instructions under: "Displaying Calculation Results...etc just under "Note" Trick is you must have calculator in "LineIO" mode For setting MODE see "Calculation Modes & cal. Setup in paper instructions.
SOURCE: Setting the default value of my calculator to display decimals
Since you bent on deactivating the very features that make your calculator so versatile and so powerful, here it is.
Press [SHIFT][MODE][2:LineIO] and you will see no more fractions, nor radicals etc. You asked for it.
Hope it helps.
Testimonial: "I bought the calculator because it was on sale and I like Casio calculators; not for its fractional abilities. I can easily switch it back now. Thanks"
SOURCE: fractions to decimals?
To change the displayed result from fraction format to decimal, press the [S<->D] key.
You can also configure the calculator to be in LineIO mode. In this mode, all results are in decimal format.
To set the LineIO mode , press [SHIFT][MODE][2:LineIO]
Hope it helps.
SOURCE: I am using FX-83GT calculator when I divide a few
Try using the S<>D(above the orange DEL button) button after you've obtained your result..
To convert a single answer from symbolic to decimal, press the S--D key (just above the DEL key). To have all answers come out in decimal format, press SHIFT MODE 2 to switch to the LineIO mode.
