Go to the computer management look for cd drive right click on it then look for the words eject cd hope that helped!!!!
Five ways to eject a stuck CD or DVD from the optical drive
Ejecting the stuck disc can usually be done in one of the following ways:
1. Restart the computer and after the chime press and hold down the left mouse button until the disc ejects.
2. Press the Eject button on your keyboard.
3. Click on the Eject button in the menubar.
4. Press COMMAND-E.
5. If none of the above work try this: Open the Terminal application in your Utilities folder. At the prompt enter or paste the following:
/usr/bin/drutil eject
If this fails then try this:
Boot the computer into Single-user Mode. At the prompt enter the same command as used above. To restart the computer enter "reboot" at the prompt without quotes.
Regards,
Alex
SOURCE: MacBook Pro intel, CD stuck not mounting or ejecting
while restarting, push and hold your mouse button during the entire boot sequence. this will force the ejection of the cd.
If you need further help, reach me via phone at https://www.6ya.com/expert/jarrad_11786570be7a2abd
SOURCE: My Macbook Pro (Intel) will no eject the CD.
1. Restart the computer. If necessary, use the reset/interrupt button.
2. Immediately after the system startup tone, press and hold the
Command-Option-O-F key combination. The computer starts up to a
text-only screen, indicating that you are in Open Firmware.
3. At the prompt, type: eject cd
4. Press Return.
5. Type: mac-boot
6. Press Return
isnt there an icon on the desktop of a disk,if so just right click it so the tab comes up and click eject.
SOURCE: disc won't eject
1. force turnoff computer than try to eject
2. use tweezers to grab it
DO NOT TAKE APART
THIS COULD RESULT IN ELECTRIC SHOCKS
SOURCE: force eject CD from Macbook
A few ways of doing this
restart mac and press down the trackpad after you hear the startup noise
if
that does not work try opening up disk utility and click on the icon of
your disk under the left hand column then go up to eject button and
click eject
or open up terminal found in the utilities folder within your applications folder and then type in drutil tray eject and then press return
Finally
what to do is try pick up your macbook tilt the macbook to the one side
and press the eject key and hopefully the effect of gravity will allow
the CD to fall out.
Hope this helps.
