Depends on which timer.
Some Kichler have analog timer built in.
Most Kichler timers are made to run constantly... with option to plug your own timer into the outlet located on front of Kichler, or to plug in a kichler-model photoeye.
Hey there, how's it going? Do you know which model of ceiling fan you have? Whether you do or don't, that's OK - I was going to suggest checking out this site below which has Kichler fan manuals available. If you don't find the one you need, let us know and we'll take a look for you through some other sites.
Kitchler wiring with block terminals. 120Volt Bare ground wire connects to GRD terminal Black hot from breaker connects to 120VAC PRI terminal
White neutral from breaker box connects to COM PRI terminal
Output to lights is shown. http://waterheatertimer.org/images/Kitchler-wiring-2a-1000.jpg
One romex wire feeds into splicer. Up to 3 romex wires can connect to romex feed. Splicing box has to be put inside covered electrical box and cannot be left in open air.
