Microsoft Windows 7 Home Premium 64BIT Operating System Software  OEM DVD Logo
A
Anonymous Posted on Aug 13, 2014
I have created a 1-page document (colored green with print) to use as a book cover. I can save the document but cannot copy/paste it to the first page of a different document (my manuscript). How is
I have created a one-page document (book cover) with a green background. The option to copy/paste this to another document (to make it the first page of my book manuscript) will not allow. When I do manage to copy/paste the page to the beginning of the manuscript the entire manuscript turns green. I only wish to move the green page to the first page of the manuscript.
Tim Dickson
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Aug 14, 2014
 Tim Dickson
Contributor
Level 1:
New Friend:
Answers
25
Questions
0
Helped
10372
Points
45
You need to specify your word processor to get more detailed help. in the mean time.... I would suggest try things the other way round. ie. make a copy of your green front-page document, then create a second page, make sure it is not green, and paste your manuscript into that second page.
Mahe Boucher Legault
Level 1:
New Friend:
  • Contributor 1 Answer
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
81
Points
Y ou mentioned that y ou have created a green page but not how you made it ....
Have y ou tried ti simply create an image and insert TNA image on tour first page ? Y ou clan adjust The seize of The image to fit The entire page
  • Mahe Boucher Legault
    Mahe Boucher Legault Aug 14, 2014
    You mentioned that y ou have created a green page but not how you made it ....
    Have you tried to simply create an image and insert the image on your first page ? You can adjust the seize of the image to fit the entire page
3 Related Answers
Anonymous
  • 265 Answers
  • Posted on Apr 06, 2009
SOURCE: problem in saving documents
Seems like there is a problem with the directory.
just simply reinstall microsoft office :)
thanks
Anonymous
  • 74 Answers
  • Posted on Oct 18, 2009
SOURCE: I have a mac book pro with osx v10.6 snow leopard.
Google the patch on thepiratebay.org or any torrent website. Make sure you have your Antivirus up as some files MAY contain malicous material. e.g. backdoor Trojan.
Anonymous
  • 99 Answers
  • Posted on Apr 26, 2010
SOURCE: I'm Making a batch File that moves and copy files, not working.
@Echo Off
:start
set /p 1=Please Enter Directory and Name of file you would like to move
set /p 2=Please Enter Directory of where the file will go
set /p 3=please select 1 of 2
options 1: copy 2: move
if %3%==move goto a
if %3%==copy goto b
:A move %1% %2%
goto c
:B copy %1% %2%
:C echo end
How to delete blank pages without going manually pages by page?
Copy all pages with text on them and paste them to a new document - save the newely created document with a new name - then delete the original document you copied pages from. https://www.6ya.com/callphilipforhelp
2answers
Why not - I have created a 1-page document (colored green with print) to use as a book cover. I can save the document but cannot copy/paste it to the first page of a different document (my manuscrip
Not sure what program you are using, an easy fix, is to rename your document to "Temp" delete all the pages that you do not want, copy the first / the only page you need, than delete your temp when done, the original file is intact.
Tony
Btw, Iā€™m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
When printing, sentences over lap so the document is unreadable. Also it may only print the first line of a document.
I've seen word documents do this sometimes and fixing it has worked differently each time.
1) Open the document and press CTRL + A (select all) on the keyboard and then CTRL + C (copy), then start a new document and press CTRL + V (paste). Save the new document as something different and try printing again.
2) Open the document again and select all and copy again,but this time open wordpad (a different program to Microsoft Word) by going to Start > Programs > Accessories > Wordpad, and paste the text into wordpad. This may change some of the formatting. Now, select all again, and copy, and start a new word document and paste.
Copying the text out of word and back in seems to work more often. Sometimes the best program to copy out to is notepad, but you lose pretty much all of the formatting when you copy back into word.
3) If this doesn't work, you could try to update your printer drivers, and if that doesn't work, as a last resort, you can delete the printer and create it again via the Control Panel > Printers.
1helpful
Have a black line on all my scanned files, runs the length of the page, about 1 1/2 inches from the left edge.
To determine if the vertical lines appearing on your printed documents are related to a printing or scanning issue, print a test page by pressing MENU, 4 (Printer), 2 (Print Options), 3(Test Print) and COLOR START.
If the vertical lines appear on the Test Print continue to Procedure A:Cleaning the Corona Wires Inside the Drum.
If the vertical lines do NOT appear on the Test Print continue to Procedure B: Cleaning the Scanner Glass.
Procedure A: Cleaning the Corona Wires Inside the Drum:
NOTE: Brother strongly recommends that customers do not use generic drumunits and/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability. The Brotherlimited warranty does not apply to any problem that is caused by the useof unauthorized third party drum units, toner cartridges or toner.
A1. Power off the Brother machine using the power switch located on the right side of the machine.
A2. Press down on the front cover release lever and open the front coverby pulling it towards you.
A3. Hold the green handle of the drum unit (labeled 1). Lift the drum unit up and then pull it out until it stops.
NOTE: If you cannot pull the drum unit out, make sure that the front cover is fully open.
A4. Remove the toner cartridges one at a time, by holding the handle of the cartridge and lifting it up and out of the drum unit.
Note: We recommend you place the toner cartridge(s) on a clean, flat surface with a piece of disposable paper underneath it in case you accidentally spill or scatter toner.
A5. Lift the white plastic corona wire cover by lifting the tabs locatedon the right and left side of the cover.
A6. Clean the corona wire inside the drum unit by gently sliding the green tab from left to right several times.
Note: Be sure to return the tab to the home position. If you do not, printed pages may have a vertical stripe.
A7. Close the corona wire cover.
A8. Repeat Steps 5 through 7 to clean each of the remaining three coronawires.
A9. Reinstall the toner cartridge(s):
NOTE: Before reinstalling the toner cartridge, shake the toner cartridgeside to side.
Hold the handle of the toner cartridge and slide the toner cartridge into the drum unit. Make sure that you match the toner cartridge color to the same color label on the drum. Fold down the toner cartridge handle once the toner cartridge is in place. Repeat this for all the toner cartridges.
A10. Push the drum unit back into the machine until it clicks into place.
A11. Close the front door and power on the Brother machine.
A12. Print a test page by pressing Menu, 4 (Printer), 2 (Print Options),3(Test Print) and Color Start.
B1. For safety reasons, power the Brother machine Off using the power switch located on the right side of the machine.
B2. Lift the Document Cover and clean the following with a lint-free cloth moistened with a non-flammable glass cleaner:
a. Run your fingertip over the scanner glass of the flat bed to check for debris. If you feel debris, clean the entire glass area but concentrating in the area in which you felt the debris. (Caution! Do notpress down on the glass very hard.)
b. Run your fingertip over the scanner glass on the left to check for debris. If you feel debris, clean the entire glass area but concentrating in the area in which you felt the debris.
c. The white plastic pad located on the underside of the Document Cover
d. The white plastic pressure bar located to the left of the white plastic pad.
B3. Close the Document Cover.
B4. Test the machine by making a copy of a blank sheet of paper using the ADF (Automatic Document Feeder) and a copy using the Flat Bed.
a. To make a copy using the ADF, place the document face UP in the ADF, press the COPY mode key located below the LCD display and then COLOR START. If the problem continues,repeat Steps 2b and 2d at least 3 additional times.
b. To make a copy using the flat bed, lift the Document Cover of the flat bed, place the document face down on the scanner glass (make sure the ADF is empty) and close the Document Cover. Press the COPY mode key located below the LCD display and then COLOR START. If the problem continues, repeat Steps 2a and 2c at least 3 additional times.
Pages are printing, but part of the page has really light, some unreadable printing while rest of page is fine. What do I need to do/change?
If the colors on printed and copied documents are too light, blurry or not as bright as expected follow the steps listed below:
1. Verify the toner save mode is turned Off. When you set the toner save feature to On, print appears lighter.
a. Press Menu, 1 (General Setup), 6 (Ecology), 1 (Toner Save).
b. Press the up or down arrow key to select OFF and then press OK.
c. Press Stop/Exit.
2. Print a document from your computer or print a demo page by pressingthe FAX and COPY keys at the same time.
2answers
Every time I scan a multiple-page document into a PDF file using my HP LaserJet M1319fMFP, in creates a separate file -- or document -- for each page, rather than simply scanning all the pages into a...
There is no easy way of doing this.
What you can do is scan each page as an image file, then use an OCR program to convert each page into a text file and save them. Then open a fresh/new Word document, then open each text file page and copy and paste each text file page into this Word document.
After you have copied all the pages into this Word document, then spell check it, edit and format the text then save the document. You can then create a PDF file from this Word document if you need to.
1helpful
2answers
How do I combine two word documents into one?
Dave,
Open document #1.
Click [Edit]
[Select All]
[Copy]
Open document #2
At the top of the document, or at the bottom of the document,
Press [Shift] and the [Enter] keys
(hold down the shift key and press enter)
This will insert a "new page"
Now, click [Edit]
[Paste]
[File]
[Save As]
Save the new "double document" with a different name.
*done*
2helpful
2answers
I highlight portions of webpage and right click copy but when i try to paste in folder the paste does not work
After you high lite it try pressing CTRL-C aka copy and then paste with CTRL-V
Some web pages disable these functions and don't tell you so try a different page as well. So the webpage won;t let you copy through the browser while the basic keyboard one will work. If that dioesn't work you either need to save or print the entire page.
Printing steps for 4x6 size photo paper
Try this :
1) Within your application click on FILE and PRINT
2) Depending on the application in use, you may see either "Printer" or "Format for". Ensure your printer name is selected here instead of "Any Printer".
3) Click the up/down arrows next to COPIES and PAGES to see all the available setting options:
A) COPIES AND PAGES
Allows you to select how many copies you want and if you want to print all pages, selected pages or a specific page.
B) LAYOUT
Adjust the way the image is displayed on the media for multiple page printing.
C) SCHEDULER
Allows options for when to print a job, such as specific time or to hold the jobs, and the priority of the job to be printed for networked machines.
D) PAPER HANDLING
More page options, such as even or odd pages only, and reverse print order.
E)COLORSYNC
Connects to color options managed by the ColorSync Utility.
F) COVER PAGE
Provides the option of including a cover page or not with your prints.
G) PRINT SETTINGS
Select your MEDIA TYPE and INK. You can also create and save CUSTOM SETTINGS through this area.
H) COLOR MANAGEMENT
Adjusts BRIGHTNESS, CONTRAST, SATURATION, and INK balance. Also gives ability to allow COLORSYNC to control all printer colors.
I) EXTENSION SETTINGS
Provides the option for printing on thick paper and envelopes * This option may not be present with all models.
K) SUMMARY
Details settings chosen in other options.
After making the changes appropriate to your set up and print job, click on PRINT.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
