Computers & Internet Logo
A
Anonymous Posted on Aug 13, 2014
Start my pc on safemode - Computers & Internet
Joel Rodriguez
Level 2:
Sergeant:
  • Expert 465 Answers
  • Posted on Aug 14, 2014
Joel Rodriguez
Expert
Level 2:
Sergeant:
Answers
465
Questions
Helped
131126
Points
831
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
When i tap f8 cant boot into safemode gets stuck in safemode need help please
dont go to safe mode jst start window normally ntng will happen
1helpful
We bought a new monitor, H163HQL, but when I tried to start the monitor "input not supported" appeard
boot your PC in safemode, this will start your PC in a 800x600 resolution, your current resolution is not supported by your new Monitor so its need to be change.
to go to safemode, press F8 while booting your OS, press power on then press F8 repeatedly until come option appear in your screen then select safemode.
good luck...
don't forget my rating, thanks
1helpful
Acer Aspire X1700 Desktop Wont Start up Shut down with blue Protection screen
That's Blue Screen of Death. Start up ur pc in safemode by pressing F8 key while booting and uninstall any recent hardware or software installations. Or try System Restore to an earlier date. If u failed to boot up ur pc even in Safemode, make a clean and fresh OS installation.
I have checked the firewall settings and it ok,, will pick up the persons pc i wish to connect to but will not connect !! i tried the usual way etc repair but will not connect at all,, it was ok a little...
You can try connecting to wireless in Safemode with Netwroking. Boot the computer is Safemode with Networking and search for wireless networks, if able to connect in Safemode with Networking then surely the issue is with security program
3helpful
My lenovo t60 screen goes black 15 seconds after
Hi, try to boot into safemode, turn your system on then keep on tapping F8 to get the windows advance Menu screen, select safemode.
In the safemode windows go to Control panel and check your power options, you will see what time frame your system has for the LCD when turning off.
If this does not fix the issue, try booting into safemode with networking for you to be able to go online in safemode try updating your BIOS from your Manufacturers Website, Updating your bios may fix the issue.
I have a Dell Dimension 8400 PC desktop. When I tried to turn it on the fan will start and it will begin to boot but then suddenly stops and the light on the front goes from green to yellow. (Not...
Try going into Safemode. If the system stays on while in safemode, when try disabling start up items.
To go to safemode, press F8 when starting the PC or while you see the Dell logo.
To disable start up items, Click on Start>Run>then type MSCONFIG, then press "Go". IN System Configuration Window, click on Startup tab, then uncheck all the items. You can also use this link as guide.
http://imasters.japancase.com/msconfig/
If the system works find on safemode, or after removing startup items, then you have a software issue. OS reinstallation is easiest approach.
On start up goes to the Window main screen, then shuts down
This issue can be hard or software or even both. I suggest troubleshoot on the software side first. Try going into safemode. To do it, tap F8 while you see the ACER logo during start up. Then select SAFEMODE. If the computer is not shutting down on its own in SAFEMODE, then its a software issue. You can back up your files while in SAFEMODE. After backing up your files, you can reinstall Windows using the reinstallation disc that came with the computer. Goodluck.
Regards,
Melgasbal
2answers
Loging
Boot up in safemode and choose administrator and delete your account and make another new one.
Your documents and files will be saved in your c: drive.
To get into safemode reboot your computer and press F8 while your computer is loading before you see a screen. Scroll up to safemode and follow the screen.
1helpful
Start menu keeps flashing on/off,dell laptop.
Hi rayo49,
Try booting in safemode. restart your computer and tap F8 repeatedly at boot up. select safemode and select windows xp.
If it does the same thing in safemode check the windows key on your keyboard. it may be stuck.
If it does not. try using system restore. start>all programs> accessories> system tools> system restore. rsetore computer to a few days back or before the problem begun
Recently installed windows xp3 service pack have to rebooth desktop with asus p4s800-mx se motherboard on emachine 21o desktop, how can do normal boot up can i remove the service pack
when start your computer press the f8 button its show the safemode click the safemode and open the windows in a safemode when your computer start then open start>all program files>accessory>system tools> system restore> open it and choose the date when your windows is working with sp2 after that click next and finish it your pc take a reboot then its restore your sp3 will be remove from your pc
thanks
rate me if solve
Grand Canyon Tech
Grand Canyon Tech
