Kitchen Appliances - Others Logo
A
Anonymous Posted on Aug 13, 2014
Have 3 pitco commercial deep fryers. Getting flames up the back flue in first fryer.
Treefrog15
Level 2:
Habit-Forming:
  • Expert 130 Answers
  • Posted on Sep 23, 2014
Treefrog15
Expert
Level 2:
Habit-Forming:
Answers
130
Questions
0
Helped
79881
Points
224
Check that the gas pressure regulator has not faied.
1 Related Answer
kebah
Angel Joseph Jr.
  • 685 Answers
  • Posted on Sep 13, 2011
SOURCE: pitco deep fryer flames coming out the fryer
Hi there.
The soot or carbon have probably build up inside the fire tubes, better check and have an authorized service technician clean them.
Make sure that the fryer is receiving the rated gas pressure and correct gas type as stated on the nameplate, this way, carbon or soot formation on fire tubes can be prevented
Regards.
I'm getting a lot of soot from my propane fired fryer. Otherwise works well.
The burner flames must be BLUE. Yellow flames will produce soot. Sounds like the burner orifice size needs to be checked.
2answers
Flames coming out the exhaust
Flames coming out of the exhaust can be caused by several things.
The fryer could be set up for natural gas and it is installed on a propane system. The fryer can be leaking oil near the burner tube and the oil is burning causing excess flame. There could be grease buildup in the flue in the back of the fryer from people hanging the baskets in the wrong place.
I have a Vulcan lg400 propane fryer it has only been used 4 times for catering events. yesterday we were using it and after a while it started what seemed like mild back drafting the flame was actually...
Hi there. Flames rolling back instead of shooting inside the fire tubes can be a result of clogged fire tubes or air entering the flue, also check if there are objects blocking the flue. Regards.
When i set the thermostat to desired setting flames shoot to the front of the fryer
Hi Dan.
Check if the fire tubes are clean, exhust system must be operating well during fryer operation. There should be no fresh air directed at the flue stack of the fryer, only exhaust.
Regards.
1helpful
My Pitco fryer is shooting large flames out of the door. . . . HELP!
Hi there.
You should inspect the fire tubes, it is a tunnel under the fry tank where the burner flames suppose to travel to heat up the oil. Your fire tubes may be clogged with soot or carbon that's why flames cannot go thru the fire tubes. Fire tubes must be free of soot or carbon deposits.
Soot build up on fire tubes can be prevented by keeping the gas pressure at standard as much as possible, low gas pressure produce yellow flame or poor flame quality and in turn will produce soot.
Also, make sure that no air or ventilation is directed towards the flue riser, otherwise, the same will result, flames rolling back towards the door.
Regards.
1helpful
FIRE IN FLUE
There may be soot/ carbon build up inside the fire tubes that's why flame crawl all the way to flue. Also check if your fryer receives the right gas pressure and type as rated on the nameplate.
Is there an easy way to get access to the rear vent to clean away soot and buildup?
You have to dismantle the back panel to have access in cleaning the flue. Soot formation or carbon build up on fryers are due to low operating gas pressure. When the fryer receives lower than the nameplate rating gas pressure, the flame on burners will be of poor quality (yellow flame) which will in turn produce soot/ carbon.
1helpful
Top Kitchen Appliances - Others Experts
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
