Question about Dometic Rooftop RV Air Conditioner
Can I get a heater kit no. A70011 for a SL110RB dometic-aire roof-top air conditioner?
Wanting to add the heat strip.
SOURCE:
SOURCE: heat strip installation
It was quite simple, just installing the heat strip and my model only required removing the grill cover and mounting the element. The other optional installations didn't apply to my model.
thanks,
Don
Posted on May 27, 2008
SOURCE: Dometic Rooftop RV Air conditioner
why is our dometic roof top a/c on our boat draining water back into boat. is there a way to clean the drain?
Posted on May 30, 2008
  • 230 Answers
SOURCE: will not shut off
Sounds like a stuck relay on the unit itself. Maybe there is a short in the control wire that comes from the thermostat that activates the fan.
The thermostat probably has one hot wire at all times. The thermostat then chooses which wire to send the voltage down based on your selection. One of those wires is probably for the fan only. Make sure that it is in good condition (no bare, pinched or wires)
Posted on Jun 17, 2008
  • 68 Answers
SOURCE: need to know how many amps the model # 57915.741 draws
Compressor amp draw is 7-8 amps
Posted on Mar 19, 2009
  • 10 Answers
SOURCE: I have a Duo Therm Roof top Camper air conditioner
how old is unit and does it have refrigerant in it
Posted on May 31, 2009
Where can I get a heater kit no. A70011 for a SL110RB dometic-aire roof-top air conditioner?
Any dealer should be able to order for you. Here's dometic site to locate nearest dealer to you.
https://www.edometic.com/allusr/srvctr.nsf/dl?OpenView
Aug 13, 2014 | Dometic Rooftop RV Air Conditioner
Rv heat pump problems
Open circuit or out of range Freeze Sensor. Air conditioner mode of operation will be locked out. Furnace, heat strip, heat pump and fan mode of operation can continue to operate but displays the last temperature set-point. There is a sensor that detects evaporator freezing, it may be bad or your freezing because of low freon levels
Sep 30, 2013 | Dometic Rooftop RV Air Conditioner
I got a Dometic roof AC (2010) on my RV , the thermostat is givng me a E5 code, I changed 3 thermostats, opened the top and inside caps to check if there's any cut or burned wires and nothing that I...
E5 Open circuit or out of range Freeze Sensor. Air conditioner and dehumidification
operation will be locked out. Heat pump, furnace, heat strip and fan operation
Sounds like your freeze sensor is defective and since it is still under warranty, you would void it if you replace it yourself.
Aug 26, 2011 | Dometic Rooftop RV Air Conditioner
I have Dometic Roof Top Heatpump Model B3200 It will not turn on when it is a cold morning. The only way to get it started is to heat up the air in the caravan using a fan heater. This somewhat stupid...
To getproper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV
Dec 30, 2010 | Dometic Rooftop RV Air Conditioner
Installing rv roof airconditioner heat strip
I see what you see also in the manual. The difference is the Heat Strip package that part is optional and the 600212-001 with the optional heat strips becomes the new 600315-001 I talked to Dometic Duo-Therm and the models are the same but they both are not heat pumps but the new heat strip package comes on when told to go into heat mode when you change the thermostat to heat. The part you purchased will fit both model numbers you listed for your roof top air conditioner. Thanks, Sea Breeze
May 09, 2010 | Heating & Cooling
How can we tell if our dometic rooftop air conditioner/furnace has a heat strip or not.
Hi; If You have a heat pump then yes on heat strips. Does Your RV have a gas heater. If You gently remove the cover some times You can see the heat coils in the metal air flow tube...Also does the compressor run in heat mode ,if not then best guess You have heat strip capability...alpharome416
Feb 22, 2010 | Dometic Rooftop RV Air Conditioner
I need to find a cycling thermostat for a Dometic Roof top unit
I ran across the same problem and found the kit to expensive. I gutted the parts added a transformer, contactor and thermostat. Unit worked great and cost about half the price.
Jan 04, 2010 | Dometic Rooftop RV Air Conditioner
Is it hard to install a heat strip in a model#57915541 serial#54936348 air conditioner
Hi, like most of the RV roof tops, they will have a manual showing the type and wattage of heat strips you're system calls for. It comes as a unit, pre-wired to fit and set in place. You should have no problems installing a heat strip kit, but make sure you get the right one that the unit calls for as they do make several models. Very self explanatory. Also, be sure that you're system calls for a heat strip package?? Good Luck, and if you need more help please contact me. Very easy to set in place and plug in. Sincerely,
Shastalaker7
Dec 10, 2009 | Dometic Rooftop RV Air Conditioner
How difficult / expensive is it to install a heat strip in a Dometic roof top AC? The unit I have has a mark on the knob for heat, but I suspect it was never installed.
Fairly easy. The only thing that you must figure out is how many amps the heat strips will draw. Make sure the fuses and the breaker switch can handle them. And be aware your electric bills will shoot up.
Oct 20, 2009 | Dometic Rooftop RV Air Conditioner
Open Questions:
See all Dometic Rooftop RV Air Conditioner Questions
Dometic Rooftop RV Air Conditioner Logo
113 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
Thomas F. Schneider
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
