SOURCE: Baumatic B180ss Electric oven problem
It sounds like the overheat safety stat is cutting the oven off.
This is prevent the oven overheating and catching fire.
They can go faulty and operate prematurely, causing the prob u are experiencing.
If it is built in , make sure it has adequate ventilation, as this can cause the prob.
Also check to see if it has an external cooling fan fitted, these can fail, and again cause the prob.
They are usually fitted under the top cover of the oven, and designed to keep the oven cool.
It should come on shortly after turning the oven on
These things are the most likely cause of the prob.
plz rate my solution.
Thanks.
SOURCE: Oven has stopped heating up
Hi.
This oven should have two elements.
If both broiling and baking element are not heating, then
the most common fault causing the problem is a defective temperature
probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line
on the circuit from electroning oven control to baking and broiling
element.
When the probe fails, it will affect both baking and broiling function.
The
temperature probe is tested reching the probe, cutting or disconnecting
its wiring, and testing the probe at room temperature, with a
multimeter set on impedance at Rx1. If the multimeter reads no
continuity (circuit open), then the probe must be replaced.
If
the temperature probe is good, then parts that may be responsible for
the fault are oven electronic control and wiring. Having both elements
failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Testimonial: "Thankyou very much for your help.Im off to buy an element first thing in the morning. Thanks again"
SOURCE: my b180ss oven will not come on.the fan and light are ok.
I would definately say that the oven element needs replacing.
You will find this located at ther rear of the the oven compartment behind a removeable cover.
