So i both this view tech internet router plz tell me how to change the password cz it has no default password set plz answer step by step
SOURCE: how to change router default name and password
you can't change the default name...that is always left blank, but you can change the password.
Access the user interface & click on Administration. It should automatically be in the Management section at this point.
Enter your desired password in the Router Password field.
Re-enter to confirm the password in the next field.
Click on Save Settings.
For more information on working with your router, you can access the User Guide provided by LinkSys:
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&pagename=Linksys%2FCommon%2FVisitorWrapper&cid=1166859837401&displaypage=download
SOURCE: forgot password to acess< and
Restore Factory Default Settings When you restore factory default settings to the base station, you clear your Internet connection settings and any special base station configurations that you have established. After the restore is complete, you will need to reconfigure your base station settings or restore these settings from a backup file. You should restore the original factory default settings only under the following circumstances: O You are experiencing serious problems with your base station, and resetting the base station does not fix the problem. O You cannot remember your base station password. In this situation, you must restore the factory default settings by using the Restore button on the base station, and then use the default password admin to log on to the Base Station Management Tool. To restore factory default settings 1. Open the Base Station Management Tool, and then click Management. 2. On the Management menu, click Back Up and Restore Settings. 3. Under Restore factory default settings, click Restore Factory Default Settings. While the original factory default settings are being restored to the base station, the Power light on the base station turns orange. When the light is solid green, the settings have been restored. If you want to open the Base Station Management Tool after the settings have been restored, type admin as the password on the Logon page. Do not attempt to log on to the base station until the settings are restored and the Power light on the base station is solid green. After you restore the factory default settings to the base station, you should navigate to each page of the Base Station Management Tool and reestablish the network settings you want, or restore the base station settings by using a backup file. For information about creating a backup file of your settings, see the following section. Be sure to establish your unique base station password as soon as possible after restoring the factory default settings to prevent unauthorized users from logging on. For more information, see “Change the Base Station Password.” please rate this answer, thanks
SOURCE: My dataone WA3002G4 (BSNL) modem is not connecting to internet
This sounds like you need to set up your main gateway or WAN port settings on the datatone to match what your ISP provides? Is it possible to get suggested settings from the ISP?
SOURCE: I have Compex WRL254G wireless ADSL router. I need Default passwo
username: admin
password: password
here is the manual too
SOURCE: how to change password for Trendnet TEW 432BRD wireless router
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Set WAN settings as your internet service provider settings.
Enable DHCP .
CLick on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Let me know if you need further assistance.
Thanks.
