Sears & Craftsman 25cc Weedeater brand new starts but will not stay running?
This is a brand new product just purchase today brough it home filled it with gas started it and everytime I try to press throttle it dies. This went on for 1 hour same result.
Re: Sears & Craftsman 25cc Weedeater brand new starts...
Try leaving the chokey partially engaged. Operate it this way for a few minutes until the engine is thoroughly heated then move to the run position. If this does not work return it.
If it has compression and spark it has to be gas. Try a new plug. If it still does not start consider replacing the carb. About $14 fro m Ebay. Make sure to replace the fuel lines going into tank. They come with a carb kit usually.
Sears
https://i.sears.com > mp-tc > prod_1977954512
PDF
WEEDWACKER GAS TRIMMER. R. Model No. 316.711192 ... 25 cc (1.52 cu. in.) 0.025 in. (0.635 mm) ... Always use the fresh fuel mix explained in your operator's manual.
Sears
https://i.sears.com > mp-tc > prod_1977959112
PDF
Operator's Manual. CRAFTSMAN. 2-Cycle. WEEDWACKER GAS TRIMMER. Model No. 316.711471. INCREDI-PULLMW/TH. UNBELIEVABLE STARTING EASEâ„¢. CAUTION: Before using this ...
Two things which may be the problem: 1) carb need to be rebuilt or replaced, and 2) you need a new spark plug. The carb with shipping is around $50.00 from sears ( http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-3167918602008/0247/1503820/P0805032/00001?blt=06&prst=&shdMod= ) A sparkplug can be had at any small engine repair shop and most auto parts stores for less than $5.00 Start with the cheap solution... Also make certain you have fresh gas and that the oil mix is correct.
fit a diaphragm kit in the carby
the pump diaphragm is the first to fail and then the float diaphragm distorts and will not let in enough fuel to keep it running
yes, there is a spark module, but it's highly unlikely that two would have a bad module - more than likely, it is your gas mix. it must be fresh for the engine to run. the gas we have today will go bad in about a month and a half. if you happen to live in an area that has E85, forget it. small engines will not run very long, if at all on this junk. in some areas, you can get gas without alcohol, but it can only be used for lawn & garden equipment. it's expensive, but your engines will run
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner. Makesure the small screen is free of debris.(Should be able to see daylightthrough it.)
Cut 1/8" off outer (aluminum) shaft. Lube inner shaft with STP or heavy gear lube
this will re-engage worn square drive .Replacing inner cable is un-necessary this is normal wear.
Sears Master Tech BB
