I want to purchase a heat strip
SOURCE: heat strip installation
It was quite simple, just installing the heat strip and my model only required removing the grill cover and mounting the element. The other optional installations didn't apply to my model.
thanks,
Don
SOURCE: Dometic Rooftop RV Air conditioner
why is our dometic roof top a/c on our boat draining water back into boat. is there a way to clean the drain?
SOURCE: will not shut off
Sounds like a stuck relay on the unit itself. Maybe there is a short in the control wire that comes from the thermostat that activates the fan.
The thermostat probably has one hot wire at all times. The thermostat then chooses which wire to send the voltage down based on your selection. One of those wires is probably for the fan only. Make sure that it is in good condition (no bare, pinched or wires)
SOURCE: I have a Duo Therm Roof top Camper air conditioner
how old is unit and does it have refrigerant in it
E5 Open circuit or out of range Freeze Sensor. Air conditioner and dehumidification
operation will be locked out. Heat pump, furnace, heat strip and fan operation
can continue to operate but displays the last temperature set-point.
Sounds like your freeze sensor is defective and since it is still under warranty, you would void it if you replace it yourself.
