SOURCE: HP laserJet 3055 network connection
HOW TO CONNECT HP 3055 TO ROUTER/WIRELESS NETWORK. WINDOWS XP/WINDOWS VISTA.
I have just finished successfully connecting my HP 3055 to my router and using it over wireless on 2 computers, one with windows XP SP2 and one with VISTA.
INSTRUCTIONS FOR CONNECTING HP 3055 ON XP:
FIRST CONNECT THE PRINTER TO THE ROUTER WITH A ETHERNET CABLE. FIND OUT THE IP ADDRESS OF YOUR PRINTER. By me it was 192.168.0.66
Go to CONTROL PANEL and open "PRINTERS AND FAXES". on the top left choose "ADD A PRINTER" click "NEXT".
In the "LOCAL OR NETWORK PRINTER" window, choose "LOCAL PRINTER ATTACHED TO THIS COMPUTER" and uncheck "AUTOMATICALLY DETECT"... click "NEXT".
In the "SELECT A PRINTER PORT" window click the radio button "CREATE A NEW PORT", click the down arrow and choose "STANDARD TCP/IP PORT".
In the window that pops up click "NEXT"
In the ADD PORT window, where it says "PRINTER NAME OR IP ADDRESS, type in your printers IP address, by me it was 192.168.0.66. The bottom line will fill in automatically. Click "NEXT".
In the "INSTALL PRINTER SOFTWARE" window, if you have the disk just choose "HAVE DISK" and install from there. If not, in the left column choose "HP" and in the right column choose "HP LASERJET 3050" (by me it showed up in the list, you can download the driver from here http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1140780&prodTypeId=18972&prodSeriesId=1161389&swLang=8&taskId=135&swEnvOID=228
click "NEXT"
In the "NAME YOUR PRINTER" window, choose a name and also choose if you want to set it as the default printer (recommended) Click "NEXT"
In the next window choose whether or not you want to share the printer, and if you do assign a printer name. Click NEXT. The next window is optional if you want to make a name, you can just click NEXT and your done! Print a test page to make sure that all is fine.
SOURCE: Scanning on HP 3055 printer/scanner/fxx doesn't wrk with vista
I am unable to scan in pdf format under vista window
SOURCE: HP LaserJet 3055 scan over network.
If you have installed the printer using Add printer and faxes then you have just install the printer drivers which will allow you to print over the network.
However if you want to scan over the network than you have to install the complete software of the printer .
If you do not have Software CD than you can download and install the software fom Link below.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1161389&prodNameId=1140780&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
Thanks and Regards
Neeraj Sharma
SOURCE: LaserJet M4345 MFP Printer: how to cold reset in HP LaserJet M4345 MFP...
[email protected]
To perform a cold reset
1 Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. This might take up to 20 seconds.
3 Press 3 four times until COLD RESET appears on the control-panel display.
4 Press 6 one time. The MFP continues its initialization sequence.
