Error 6800, with Japanese text, appeared simultaneaous with smell of something 'burning' inside printer. Changing to service mode gives a blank screen (no options to choose form). Could you suggest a line of analysis for this problem?
According to the service manual an error has occured writing to the eeprom on the logic circuit board. I would look at the logic board as a culprit . You may need to check the voltage is correct at the power point and matches the printer required supply voltage. What worries me is what caused the logic board to fail and make a burning smell. Could be a faulty voltage regulator supplying the logic board or a fault in a power board..
http://internaute.free.fr/depannage_canon/mp610/mp610-sm.manuel.reparateur.pdf
SOURCE: Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
SOURCE: Canon MP830 Service Error 6000
Canon PIXMA MP830 all-in-one Inkjet Printer
Error code 5C10 on computor screen and on the printer it says 6A00
SOURCE: service error 6A00 in my canon ip 5200 printer. what should i do
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: Canon MP190 not printing using only black ink, color ink finished
hai there...you try press the reset and colour button in the same time...the printer will back to normallyl
